Question about GPX PDL705
Battery pack doesn't charge
When I plug in the red charge light goes on (red) foe one second and thengoes out, Leaving it plugged in for hours does not result in a charge. It does run when plugged in. When I measure voltage on the battery using a volt-ohm meter, I read 0.3v on the right hand most contact and nothing else.
  • jbmiller54 Jan 27, 2009
    I cleaned the terminals but it did not help. Is there a repair or fix-it place that can check the circuitry. I am in Gaithersburg, MD 20886.
    Sergeant:
  • 250 Answers
The battery voltage is perfect as what you have mentioned.its the problem of the connectors to which the battery is connected that connectors r either loose or dirty thats why the battery is not getting detected.the connectors needs to be checked and made proper.
Posted on Jan 27, 2009
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
My Sloney E reader doesn't seem to be taking a
Because the battery is not removable? Best thing is to allow the E Reader to be completely cleared of any charge. OR While it is plugged in, press and hold the power and N buttons simultaneously for 20 seconds. I then turned the device on normally. Hope this help, have a great day..
Feb 24, 2012 | Sony Computers & Internet
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
FS240BX battery how Long should it take to charge.
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
Jan 22, 2011 | Black & Decker Firestorm Slide Battery
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
My HTC smartphone wont turn on or charge and when I plug it in it shows a red light instead of an orange one. Do you know why?
Have you tried leaving it to charge (with the red light on) for a few hours. The red light usually means a completely drained battery that needs a few minutes/hours to recharge.
Also, try cleaning the battery connectors with a rough toothbrush...
Dec 10, 2009 | HTC VX6900 Battery
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Fisher price dvd player - Need instruction manual
Check the Fisher Price website for an instruction manual. My daughter has one and when you plug it in and the red light is blinking that means the battery is charging. It has a battery pack inside (not removeable) that needs to be charged for 8 hours before the first use, but I'm guessing yours is used, so just let it charge until the light goes off.
Jun 10, 2009 | Televison & Video
W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Mar 14, 2008 | Cell Phones
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
GPX PDL705 Logo
99 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
