Question about American Standard - Lavatory Faucet - Single Hole - Seva - 1480.105.002
Need to replace working parts , push button , one piece toilet
This american standard one pice toilet is apprximately 22 years old
the push button is rusted out, and the flush actuator needs replacing
  • Thomas F. Schneider May 11, 2010
    All these parts are available for Americal Standard toilets. I am
    still working on some 1938 models Standards on a regular basis.
    Scholar:
  • 50 Answers
Here is a link to a site with a ton of replacement parts for amstan toilets.
Without model numbers etc. its hard to know exactly what parts you need but you should be able to look at the pictures on the site and order the right parts...
http://www.plumbingsupply.com/amstan.html
HOpe that helps...
Posted on Feb 09, 2009
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Sep 20, 2013 | American Standard 2004.014 - Champion...
50 year old American Standard toilet . Bowl fills up ,makes noises like it's pluged & then flushes
You have a blockage in the trap as the water goes out . What happens is that there is so much pressure with the water building up in the tank,, that it finally pushes the water out. Also check the vent above the toilet which is located on the roof. It must be free of debris to allow the pressure to stay equal and not a vacuum.
Feb 18, 2013 | American Standard Traditional Champion4...
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
My one piece elongated bowl toilets are filling for no apparent reason between flushes what can I do to fix the problem
it sounds like your flapper (flush valve) is leaking.
if you here your toilet filling up and no one flushed.
push down on flapper to see if you here the water stop leaking out. if so replace flapper. even if toilet is 1yr or less old. could be a bad flapper. hope this helps. duane :)
Oct 11, 2009 | American Standard 2002.014 - Champion4...
We have american standard toilet model 4260 that runs all the time. have replaced seal twice. toilet is only 2 1/2 years old. what do we need to replace?
if it doesn't fill, it's your flapper, if your tank is full then you'll need to adjust the float. take a look on amazon for those 2 parts, and read into reviews. here: Modern Shower Doors at Amazing Prices. cheers
Sep 19, 2009 | Home
Replacing my toilet's seat disc
http://www.americanstandard-us.com/customerservice/Care/TroubleTreeDetail.aspx?TopicID=2&Depth=2&AnswerText=Two-Piece%20Gravity-Fed&QuestionID=107&ModelNumber=&ProductType=2-Piece%20Gravity&ProductName=
Follow the link above, it will probably answer any questions you may have for your particular toilet. They are all different and without the model number, it's hard from my point of view to understand what you may need. Hope this helps you!
Mar 21, 2009 | American Standard Home
American Standard toilet settings screws not adjusted right
sounds like an old tiolet (3.5 gpf) my best answer is to replace with new fluidmaster! (lowes or homedepot) easy fix!
Mar 10, 2009 | American Standard Colony 2388.012.222...
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Dec 15, 2008 | American Standard Home
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
American Standard - Lavatory Faucet - Single Hole - Seva - 1480.105.002 Logo
1,048 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
