Question about LG 32LD350 32 in. LCD TV
Lg ez adjust menu restore speaker sound - LG 32LD350 32 in. LCD TV
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Is it possible to enter EZ-Adjust menu on LG 32LD350 with my Philips SRP2008B universal remote control?
0067,0061,0068,0063. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Nov 29, 2013 | Televison & Video
Can not access to LG 47LF11-UA EZ adjust menu
If you are using a universal remote cotnrol, it won't.
Aug 26, 2013 | LG Televison & Video
How do I adjust the brightness on the monitor LCD 23in Wide W2361v-pf. There is no sound when playing music.
First check for the menu buttons. This is where the control on you monitor is adjusted. Just click the menu button and this will shows the available adjustment for your monitor. IF not is there a remote? if there is one then try to look for the menu button.the sound problem might be on the speakers. Check the speakers using a multimeter. The reading must be between 6 to 8 ohms.
Hope this may help you
Aug 20, 2011 | LG W2361V-PF 23 in. Widescreen LCD Monitor
I have an LG LHT764 Theater System and having a problem with the bass. I would like to know how to turn it down..
In the 5.1 Speaker Setup Menu you can adjust each speakers volume from -5dB to +5dB. You can also adjust the distance the each speaker but not for the Subwoofer.
Jun 07, 2011 | LG LHT764 Theater System
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
Audio problem
possible conditions of malfunctioning audio on PC desktop
Hardware conditions
1. The computer speakers are malfunct
a. The computer speakers have a blowout
b. The computer speaker are misconnections to the computer
software condition
1. The computer has missing audio programs
a. A restoration of the computer program systems requires peripheral system function adjustments or updates
Repairing computer hardware malfunctions
1. check for misconnections between computer to speakers. The speaker connectors should be inserted in the audio output posts on the computer.
2. A restored computer to new version of operating system would have obmitted the patch codes to a speaker that was disconnected during the process.
Repairing computer software malfunctions
1. Open up a multimedia player on the programs menu, examples windows media player, real one player, jukebox players, apple players.
a. Select a soud file from the player list category to be played.
b. A functional media player would display a sound file represented with a status bar about the sequence of motion generate.
c. The sound at which point requires out devices like speakers attachments to the computer ports to be heard.
4. A connected computer speakers should display sounds of the clips being played on two conditions
a. First, the sould loudness has not been muted to a shut down
b. Second, the sould loudeness has not been reduced least being heard
Important notes
1. hardwares required to generate sound from a computer, an intergrated speaker on the monitor or an external speaker device connected to the system tower unit,
2. Software programs on the system unit are available, examples real media players
3.A system restore to computer defaults alters the conditions of connectable devices like speakers requiring adjustments. Note, a missing program contributing towards achieving sound soon after a media player has been launched, a sound file selected, would display a message prompt requiring UPDATES, UPGRADES or MISSING DRIVER CODES
contact expert technical support
Dec 20, 2010 | Computers & Internet
TV service menu
press OK on the remote and OK on the TV panel at the same time, after 5 to 10 seconds, the service menu EZ adjust should appear.
another step is to press menu on remote and menu on tv at the same time..
Feb 01, 2010 | Televison & Video
LG LT20 Laptop Wireless
You turn the wifi on by the EZ Menu
Dec 24, 2008 | LG X-Note LM50 Notebook
I have an LG 752 DVD player but when playing pre-recorded DVD films on it you can't hear the actors very well. All speakers seem to be working okay and it all seems to be properly connected. The actors...
Be sure to match the speaker cables to the appropriate terminal on the components: + to + and - to -. If the cables are reversed, the sound will be distorted and lack base.
Also, adjust the sound mode through the menu button on the remote.
I hope this help :)
Jun 21, 2008 | LG Televison & Video
LG 32LD350 32 in. LCD TV Logo
43 people viewed this question
