Question about Hobart Slicer Automatic 12"
How to lubricate old hobart slicer 110 model
I have an old Hobart Model 110 slicer from approx 1939and need instructions to lubricate. What type of oil and grease does it require and where exactly do you lubricate it. Also looking for operating manual .
ginko
  • 19396 Answers
SOURCE: HObart MOdel 1712 Slicer Sharpener
The tw sharpener stones should be fixed with the screw provided to the blade
Posted on May 08, 2008
bigg t
  • 640 Answers
SOURCE: I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Posted on Aug 07, 2008
ricardok45
  • 135 Answers
SOURCE: Requesting instruction and operation manual for hobart Mixer
Nelson. Go to www,hobartservice.com and register. Once you are authorised to log on find the Product Group choices, select Food Machines and then select Mixers. On the left side of the page click on discontinued products and then look for your mixer. Make sure that the file you choose matches your ML# on your mixer's info plate. You'll find everything that you need there, including parts lists and use directions.
If you find this solution helpful please rate it. Good luck. ricardok45
Posted on Jan 05, 2009
ricardok45
  • 135 Answers
SOURCE: Instruction Manual for HOBART MIXER. How to get a copy
Hi Nelson. The next time you have a question please provide the Make, Model # and serial# of your mixer. This info will get you a faster answer to your question. It takes a little while to get used to this website. It took me a little while too.
Having said that, go to www.hobartservice.com, register and once you have been granted permission to access the website, you will be able to find all kinds of information regarding your mixer. If you have any trouble with the Hobart site, let me know, and I'll walk you through it. If you find this solution helpfull, please rate it. ricardok45 Good luck!
Posted on Jan 07, 2009
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
May 08, 2008 | Hobart A200 Stand Mixer
Hello, I have a commercial dough mixer,
it's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
Oct 10, 2009 | Hobart D300-6036 Mixer
How to remove and replace a hobart slicer blade model 2712
PHIL SMITH HOW DO YOU CHANGE THE BLADE ON HOBART SLICER 1712??
Sep 09, 2009 | Hobart Food Processors
Worm gear hobart slicer
What is the model number?
Apr 06, 2009 | Hobart N50 Stand Mixer
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana dlbwholesalers@hotmail.com The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
Service parts list of hobart mixer a120
There is a website called onesharpstore.com that specializes in food processing appliance parts. I saw the hobart model 1812 listed there just today (03/07/09). They even have a number you can call direct. 772-770-4383.
Jan 20, 2009 | Hobart D300 Stand Mixer
I want to buy some oil to lubricate my hobart slicer .what to use
If you can, remoove the blade - very carefully. Clean everything where you can. It's a virtual trash holder under the blade. Where the blade mounts, you can use mineral oil to lubricate the bearing. If it makes any contact with food, it won't hurt you.
Dec 31, 2008 | Food Mixers
Hobart Slicer Automatic 12" Logo
51 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
