Question about Diamondback Fitness 910Sr Recumbent Bike
Diamondback 910sr problem
Loud sound and vibration from left pedal, at top of loop
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Details I record drum/ bass and synth loops into logic and then send them to the rc50 loop pedal, i had 50 seconds of recording time left so i added a new track which left me 25 seconds of recording t
Likely the memory is fragmented into tiny snipets much like hard drives get. For looping, the memory likely has to be contiguous chunks. Clear the memory and load each in sequence.
Feb 23, 2013 | Audio Players & Recorders
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 | Boss Rc 50
How do I operate the gear shifters on a diamondback sorrento?
Here's a great article on that subject. The article covers virtually any multi-speed bike, including yours. One thing the article leaves out is that in order to shift, the chain must be moving, which means that you must be pedaling. But it works best if you are pedaling very lightly.
http://bicycleuniverse.info/eqp/gears.html
Jun 30, 2010 | Diamondback Sorrento 26" Mountain Bike
It vibrates but has this loud noise with it about every 5-10 minutes
Sounds like the compressor is going out on thermal overload. Call a service technician to look at it.
May 27, 2009 | Whirlpool 17.6 cu. ft. Top-Freezer...
Why does my car vibrate and noisy at red light and stop sign
Maybe it's the transmission itself. check it.
Jun 17, 2008 | 2002 Kia Rio
Vibration
The small switch on the top of the left edge of the iPhone turns on/off the vibrate function. Ringtones are affected by pressing the longer switch just below the vibrate switch.
Jul 25, 2007 | Apple iPhone Smartphone
Diamondback Fitness 910Sr Recumbent Bike Logo
Top Diamondback Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Diamondback Exercise and Fitnes Expert? Answer questions, earn points and help others
