Question about E-Machines (308714) Motherboard
Emachines computer not turning on - E-Machines (308714) Motherboard
  • rbramhall Jan 31, 2009
    I have an emachines W2888, about 4 ½ years old. One day it shut off on it’s own, and I haven’t been able to get it back on since. I checked the power connection, the cord, replaced the power supply and the cpu fan, but it still will not go on. Neither of the fans go on and it doesn’t sound like there is power to the hard drive. When the power cord is plugged in, I do, however, see a very tiny green-colored LED light lit on the top of the motherboard, so there is obviously some sort of power getting through. What should I try next?
  • mgavin May 01, 2009
    Exact same problem.
  • 56 Answers
IS ALL CONNECTION CORRECT, TYPE IN
EMACHINE COMPUTER DOWNLOAD DRIVES
ENTER
SEE IF ANY OF THIS INFO CAN HELP YOU
THE MAIN SWITCH FROM THE PANEL ON THE FRONT OF YOUR COMPUTER DIDNT MATCH YOUR NEW MOTHERBOARD CONFIGURATION
START BY REMOVING ALL WIRES AND CONNECTORS EXCEPT POWER ONE, SEE IF SYSTEMS TURNS ON, THE POWER SWITCH MAYBE THE PROBLEM, RESET SWITCH, ANY EXTRA CARD YOU PLUG INTO YOU MOTHER BOARD
*********REMOVE ANYADD ON CARD ANY ADAPTER DEVICE ALSO,
ADD ONE WIRE AT A TIME UNTIL ALL WIRES ARE CONNECTED
CANDYMANCANDY
Posted on Jan 27, 2009
My desktop pc will not go to factory restore setting
Most people who own an eMachine computer will find that they will need to reset the computer at some point. It is a fact that PCs are more prone to viruses and malware than Macintosh computers. Sometimes the only way to restore an eMachine is to simply reset it. Fortunately, it is not a difficult process to reset an eMachine computer.
Turn off the computer. If the computer is in a state that it can be properly shut down, follow the normal shutdown process. On the other hand, if the computer is not reacting to anything, simply pull the cord from the wall. Restart the computer. Plug the computer back into the wall and press the Power button. Wait for the eMachine to reach the screen that reads "Press F11 to start recovery." Once this screen appears, press the F11 key on the keyboard multiple times to make sure that it registers. If the recovery screen does not come up, you will need to turn the computer off and back on again and attempt to press the F11 button again when the prompt appears. Select the proper option. After the recovery screen appears, there will be a list of recovery options. Scroll to the option that says "Full System Restore (with Backup)." Choosing this option will copy all of the contents of the hard disk to the c:\\My Backup directory. This will ensure that important files that have been created on the computer will not be deleted. However, the applications on the computer will need to be reinstalled. Allow the system restore to run its course. Depending on the age and effectiveness of the eMachine computer, it is possible this process could take up to 45 minutes. When the system restore is complete, the computer will restart itself. Reinstall applications. Any of the files created on the computer should be saved. However, the applications that created them need to be reinstalled.
Emachine Support
http://support.gateway.com/us/en/emac/default.aspx
Mar 16, 2013 | E-Machines eMachines Desktop PC
El1210-09 won't shutdown
Step 1:
b>
Feb 07, 2013 | eMachines EL1210-09 PC Desktop
How to download a full system recovery file on emachine model W3650?
(1) Go to start menu(2) Click on all programs(3) click on Emachine(4) click on Emachine recovery management(5) Click on restore on the bar across the top(6) click on restore to system factory default
Some emachines can be restored by pressing ALT+F10 as you turn on the computer, but not sure on your model
Feb 05, 2012 | E-Machines eMachines Desktop PC
How do i restore my emachine w3619 without a restore point or ****?
If your trying to restore your machine back to factory setting then you can follow the steps below: 1. Go to start menu 2. Click on all programs
3. Click on Emachine
4. Click on Emachine recovery management
5. Click on restore on the bar across the top
6. Click on restore to system factory default or 1. Turn OFF you computer 2. Press and Hold ALT key then tap F10 8 times immediately after you turn you computer on. Hope this information will be helpful. Thank you forusing FIXYA.
Apr 16, 2011 | eMachines W3619 PC Desktop
My emachine computer will not allow me access it comes on and then it will pop up with techical error followed by six zero and I want to know what can I do to fix it
It seems that your installed copy of Windows has gone "beserk".
Turn the computer off.
Turn the computer on.
Keep pressing the F8 key, until you see the Windows "boot-menu".
Choose "Safe Mode", and see if it will startup, in a minimalist way.
If not, then insert the eMachine "System Recovery" CD-ROM.
Turn the computer on, and tell the computer to boot from the CD device, rather than booting from your 'C:' disk-drive.
Choose "Repair Windows", and see if your installed copy of Windows can be "repaired".
Nov 27, 2009 | E-Machines eMachines Desktop PC
My emachines desktop crashed,wouldn't even let me go into safe mode. when I try to use the recovery dvd that I just bought from emachines, I keep getting error code 4. Where do I go from here?
ok try this. turn on your computer and put the disk in and turn off the computer right away and turn it back on and the recovery screen should pop up and go from there hope this helps
Sep 24, 2009 | E-Machines eMachines Desktop PC
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
Emachine T3414 monitor
Turn off the computer and monitor. Disconnect the monitor. Turn on the monitor. You should get some indication the monitor is on, if not it is probably dead.
If the monitor seems to be on, try to enter the menu by using the buttons or knobs on the monitor. If the menu comes up, the monitor is probably good and you have a computer problem.
If you think the monitor is bad, hook it up to an operational computer. If it works, you definitely have a computer problem; if not the the monitor is definitely dead.
Either way try to have the problem resolved under the warranty.
Nov 01, 2008 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
E-Machines (308714) Motherboard Logo
696 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
