Question about Desa International White Wireless Plug In Door Chime
How can i order a desa wireless door bell for a desa wirelss door chime tr-0035-rx
3 Suggested Answers
SOURCE: I have a desa TR-0081-BX
There is a little "diode" that should have been provided as part of the unit...it's a little wire with a B-B-sized circuit in the middle that has to be connected to the push-button at the door. This "extends" the circuit from the button to the chime unit for the full 8-notes. Hopefully you still have that part (I just about threw out mine before I read the instruction manual thoroughly. My diode just "shorted" after I power-washed my house...and I am in search of that particular part. I contacted Heath Zenith...hopefully they will give me a solution on how to get only that part. In any case, you need that diode to get the chime to play correctly.
Posted on Mar 27, 2011
  • 3 Answers
SOURCE: I bought a new door
ok.the bell have number or setting put the number in the right order.one at a time.good l
Posted on Apr 01, 2011
How do I change the music or chime on my 6195-/rx
The manual available from the link is for a Desa door bell and might be similar to yours. Check the procedure for selecting tunes.
http://www.heath-zenith.com/data/manuals/598-1000-05.pdf
Sep 23, 2014 | Office Equipment & Supplies
I need a new push button for an sl6195 rx
Heath-Zenith (I beleive they bought DESA) makes a battery remote push button bell that says its compatible with all Heath Zenith chimes. I bought one at Home Depot and it worked for my SL-6195-RX. (an on line doorbell seller and the Home Depot assoc all said it wouldn't work.)
UPC is 16963961975.
Item also shows a code "11G43" on a sticker on the back of the package.
Nov 04, 2011 | Desa International White Wireless Plug In...
I have a desa TR-0081-BX wired door bell. When you push the button it only gives a short chime . If you hold the button down it goes thru a 8 note chime what can be done to fix this. There is only one...
Mar 15, 2011 | Desa International White Wireless Plug In...
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
Why does chimes sound when no one as pressed bell
water can get into the button on door inside is a spring that pushes a part of the switch away from the other and when someone presses it they join together and bell sounds but if the rain gets inside it can make an electrical connection between the two points open it up and see if there is any trace of water the just put a bit of pva glue over the top join on the switch it will water proof it and will also be easy to remove or it could be a low battery or if mains anything can set them off mobile phones tv any thing that sends a rf signal its best to have as small a gap as possible between the two units
May 20, 2010 | Desa International White Wireless Plug In...
'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Jan 19, 2009 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
48 people viewed this question
Top Desa International Home Security Experts
Steven R
Julian Pearson
Level 1 Expert
Halim Hartono
Halim Hartono
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
