Question about GE 106591 Coffee Maker
Ge 169164 put in 12 cup water stop at 4cups - GE 106591 Coffee Maker
  • and7883 Mar 05, 2009
    same issue, but the problem is intermittent...
  • 4 Answers
I have the same problem the water filter is on too tight try lifting the filter a Little bet high or twist the filter or your filter might need to be change hope this answer works for you.
Posted on Mar 09, 2009
How much water and coffee is needed for a GE 42 cup coffee urn? Thanks,
8 X 42 = 336 ounces / by 128 = 2.625 gallons of water
1 cup of coffee/10 cups = 4cups of coffee for the batch...
heatman101
Nov 17, 2010 | Vacuums
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
KBC12BLK coffee maker -- need to purchase a new carafe -- where?
I had the same thing happen when my carafe broke. Mine is 238.69328 which is the black coffee maker. The simple solution is to head to Walmart and buy the GE replacement carafe. It's the 12 cup capacity one #169164. The box has 169180 on the bottom and it works like the old one and looks just as good no matter what color your coffee pot is.
Costs about $10.
Jun 20, 2009 | Kenmore KBC12 Coffee Maker
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Jan 27, 2009 | GE 106591 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee maker clicks but does not brew
This information is for the GE model number 169164 12 cup digital coffee maker.
The Micro fuse is shorted open. There are two underneath the housing. They are made by MICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. If not you've identified the bad one. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces.
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers.Reassemble and your back in business as a Barista.
Note: There are four Phillips head screws under the rubber pads. The three unusual screw heads may be removed/installed with a small screwdriver installed in just one of the slots.
Nov 16, 2008 | GE 106591 Coffee Maker
GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
Kenmore replacement carafe
Replacement carafe can be found on amazon, here: Amazon com Kenmore replacement carafe. Wish you best of luck. Mike
Nov 16, 2006 | Kenmore KBC12 Coffee Maker
GE 106591 Coffee Maker Logo
190 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
