Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer and dryer do not work
Power is available to area where stacking washer and dryer are but for some reason washer and dryer are not working. dryer had clothes inside and stopped almost at end. washer was finished
  • 5217 Feb 03, 2009
    solved problem now working
  • Anonymous Mar 14, 2009
    my whirlpool washer will not dran so we adjusted the hose, than it dran but not it will not fill, or spin, the water just runs out of the hose and we have the hose back up in place, please help
Wires were shorting each other out that go into plug - once took apart saw the sparks so just cut and shortened wires and reconnected them to plug
Posted on Feb 01, 2009
Can stacked washer dryer be separated?
no that's a one peace stacked washer,dryer
Nov 27, 2017 | Kenmore Dryers
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Does this combination unit need both a 220 volt for the dryer and a 110 volt for the washer?
yes in that way work. Is o.k the power for dryer will be more strong that the washer, The reason is heating elements fro dryers.
God bless you
Sep 28, 2012 | Whirlpool LTE5243D Top Load Stacked...
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
I have a Kenmore washer model no.4174102000 that has broken and was advised it cannot be fixed. I have a Kenmore stackable dryer model no.41781042000 and am being told by Sears that I have to buy a new...
a stack unit is a very risky investment, altho it's understandable if you have limited space. if the hold downs on the washer are rusted out or broken thru you need to have someone weld them for you. That's how we used to do it where I worked but stacks are not usually easily worked on. I'm afraid you will probably have to get an entirely new unit or maybe a used one from a reputable used appl. dealer in your area. Check around, you might get lucky and find one relatively inexpensive
Aug 24, 2009 | Kenmore Washing Machines
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Stacking kenmores
Yes. When I bought my washer and dryer, it came with the stacking kit.
Jul 21, 2008 | Kenmore 44072 Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
109 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
