Question about Epson T50 InkJet Printer
Ink catridge cannot be recognized - Epson T50 InkJet Printer
    New Friend:
Then change ink catridge
Posted on Aug 15, 2013
PROBLEM WITH CANON MP495 I CHANGED MY INK CARTRIDGES AND CANNOT GET THE INK LEVEL INDICATORS ON SCREEN TO RECOGNIZE THE NEW CARTRIDGE. IT STILL REGISTERS AS EMPTY.
the main problem is with the catridge, if you have check it with other printer and the catridge is working then you have to service your printer , you can try by clean the catrridge carrage with soft cotton . most of the time it work , if not then you have to replace it
Jun 07, 2013 | Canon PIXMA MP495 InkJet Printer
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Doesn't recognize half full ink cartridgesand won't print from computer command. will print from self test.
In some case the printer cartridge ink may dry up if it exceeds the mentioned period after installation, in that case it will not show recognize the catridge level. Kindly replace the cartridge and see the difference.
May 08, 2010 | Brother DCP-110C All-In-One InkJet Printer
Lexmark p6350 error ink catridge not compatible
are you using a replacement ink cartridge? if youre not using a genuine lexmark ink cartridge and the replacement wont be recognized by the printer it means that the replacement ink cartridge is not supported by the printer
Nov 20, 2009 | Lexmark P6350 All-In-One InkJet Printer
After E4 display, cartridges will not move over to the left.
E4 says no ink, press the OK button to continue, and replace the ink.
Sep 15, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My HP 6500 on install will recognize Cyan ink
Solution:
1. Try to determine whether the catridge is at fault. How so? Switch the Magenta with the Cyan catridge. Press OK.
2. If system indicates that the Magenta is not installed, you will know that the Cyan that you put there is at fault.
3. Touch the 9 mm. hole where you can see the sponge. Does the Cyan color transfer to your finger? If not, the catridge is empty or dried up. Replace or refill.
4. If the ink is normal, then use some toilet tissue to wipe the gold contact points clean. If this fails to solve your problem, take it to your dealer and ask for a replacement (if it fails to work in their machine).
5. If this fails, then the problem is within your HP 6500. You need a technician.
www.catherinecollege.net
Aug 08, 2009 | HP Officejet 6500 Wireless All-in-One...
Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Jul 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Cartridge problem
Please remove the printer catridge and clean the the extra ink in the catridge holder and in the catridge connection point with the soft cloth without damaging the cables in the catridge and the holder then test it
T.Boopathy
Jul 22, 2008 | HP PSC 1610 All-In-One InkJet Printer
Refilling ink tank
please donot use refilling system it is not for printer
it is new catridge after finishing you can refil for once dont use more times
it depends upon refilling-the quantity-before refilling you should clean with boiling water and then start refilling-if you shake the hands it ink will come out nozziles then use if not see the contacts of the catriges-if not just replace new catridge
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Epson T50 InkJet Printer Logo
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
