Question about RELIANCE ELECTRIC WATER HEATER
Wiring diagram for a model 64020RS - RELIANCE ELECTRIC WATER HEATER
Ge wiring diagram
see if you can remove back panel and push it back through hole. fasten it so you wont lose it again.
May 13, 2014 | Water Heaters
GeoSpring GEH50DNSRSA wire diagram
Here are all the resources that are available for GE heat pump without calling GE and hearing them tell you to call service technician:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
There is no wiring diagram for the bundles of wires coming from chip control board.
As general rule, these things are made to last 10 years, and afterwards will not function or be repairable. It's like a window air conditioner, except connected to water pipes, and connected to computer chip and multiple sensors, each susceptible to failure, and then the machine is used 24 hours a day, 365.
Designs have changed continually from 2009 to 2010 to 2012 models.
It's likely you got a nice piece of junk with depleted anode rod and failed sensors that stopped working and somebody got rid of it because it wasn't repairable.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Add a comment
Jun 02, 2013 | Reliance & 40 Gal Electric Mobile Home...
Do you have a wiring schematic for a Rheemglas model 81V66DB ser # RH0500408476?
I can't identify that model number, and Rheem does not show that model:
Open following link to help identify water heater:
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
Contact Rheem:
http://www.rheem.com/Contact.aspx
Oct 07, 2011 | Water Heaters
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
RELIANCE ELECTRIC WATER HEATER Logo
210 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
