Question about Dyson DC40 Animal Upright Vacuum - Self-Adjusting Cleaner Head Include
Dyson dc 40 self adjusting suction doesn't work
5 Suggested Answers
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
Dysonteam
  • 167 Answers
SOURCE: A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
  • 9 Answers
SOURCE: Dyson DC 24 is clogged, not suctioning. How can I
I removed the flexible tube sections and blew compressed air in reverse flow path to remove the clog. however I have noticed my vacuum getting clogged more often and would like to know how to clean the insides of all the pipes to remove residue alloing buildup
Posted on Jul 08, 2010
SOURCE: My Dyson dc 18 slim extender wand has NO suction.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Posted on Sep 10, 2013
Why does it have too much suction?
There may or may not be a height adjustment to be made
Dec 30, 2015 | Dyson Vacuums
Brand new dyson DC40 has no suction at bottom
Hi Marin, it's Jack at Dyson.
DC40 is a powerful mid-size Dyson upright vacuums, and we wouldn't expect you to have any concerns about performance on hard flooring or carpet. As long as the machine is used and maintained as described in the User guide we would not anticipate a change in performance, and we're on hand to help if Dyson owners need assistance.
It's important to note that for effective pickup, the cleaner head needs to form a close seal with the floor surface. Simply placing a hand under the cleaner head does not give an accurate idea of suction as you're not creating a seal, as you would be when you place your hand right across the end of the wand or hose. If you turn on and recline the vacuum, turn off the brush bar then lower the cleaner head onto something like a sheet of newspaper, you should see the newspaper held tightly against the soleplate by the vacuum's powerful suction.
We're keen to discuss this with you, and to help ensure your DC40 is working as well as it should be. Please email your full contact details to my colleagues at askdysonUS@dyson.com, and one of our experts will be in touch as soon as possible to provide further assistance.
Feb 14, 2015 | Dyson DC40 Animal Upright Vacuum -...
Dyson dc40 no suction when removing hose
Check out my video on YouTube nclogging your Dyson DC 40
Or go to you tube Dyson DC 40 won't suck from the floor part
https://youtu.be/ZoPr-gh86no
Feb 03, 2014 | Dyson Vacuums
Loss of suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you've had difficulty with your DC44 Animal. It's normal for air to blow out of the back of the machine - this is where the exhaust air is returned to the room after passing through the cyclone pack.
However, if your machine doesn't seem to be picking up as well as usual and you've recently washed the filter, this may be due to a blockage. To check the motorised carbon fibre floor tool, wand and bin inlet for any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
The motorised carbon fibre floor tool is driven by it's own motor, rather than the machine's airflow. If it isn't rotating, the video attached should help you locate anything which could be jamming the brush bar. Make sure you remove any threads or hair from around the brush bar carefully using scissors, taking care to avoid causing any damage to the bristles.
I'm confident this will resolve the issue, but if you would like some further help you can reach the Dyson customer Helpline directly by calling us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack - Dyson Online Customer Support
http://www.dyson.com
Jun 09, 2013 | Dyson DC44 Animal Cordless Vacuum Handheld...
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson Vaccum no suction Rollar works but no suction
Sorry to hear you're having difficulties with your Dyson cleaner. Our advice would depend on which model you own, which you haven't specified in your question. If you visit www.dyson.com and click 'Support', you should be able to identify your machine and run through some troubleshooting checks which should help you resolve your issue. If your cleaner doesn't seem to have as much suction as normal, you may find it helpful to check for blockages and wash the filter.
If you have any trouble finding your model, or if you've run through the troubleshooting guides and are still having issues, it's probably best if you get in touch with us directly. One of our experts will be happy to provide further assistance - you can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Aug 08, 2011 | Dyson Vacuums
Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Mar 14, 2010 | Dyson DC25 All Floors Bagless Upright...
Dyson Dc 14 All floors
When i had this problem it was the bearings on the brush it self. I got a replacement brush and now all is fine ?
hope this helps
Jan 25, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC40 Animal Upright Vacuum - Self-Adjusting Cleaner Head Include Logo
43 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
