Question about HP Office Equipment & Supplies
Every document is recorded
I cannot print as when I TRY THERE ARE ALWAYS A QUEUE of documents waiting and even when when I try to clear them there is always one shown as being 'deleting' Can this be avoided pse?
  • ianpamhobbs Jan 28, 2009
    Many hanks for interest - but it still does not work!
  • Russ Andrews
    Russ Andrews May 11, 2010
    Restart both the PC and the printer. Check the que again. It either should be gone or will allow you to delete it now...
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
What to do if after canceling the printing in queue document its status is still showing deleting ?
Give it a few minutes. Sometimes it takes awhile to delete the document.
If that fails, turn off the printer, wait a minute, then turn it back on. The document should be deleted.
Jun 29, 2015 | Office Equipment & Supplies
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Everytime I go to print a document, it won't print. I go to open all active printers and it has documents I've tried to print in the past that didn't end up printing, and I go to delete or cancel the...
1. make sure to check if the hardware is able to make color copies, that way u can be sure there is no harware issue. 2. You can download and run an HP utility tool that can help you fix the problem instantly from this page: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&lang=en&softwareitem=mp-91788-1 3. If you still get the same issue, restart the computer and check the print queue. If there are no print jobs in the queue, you resolved the issue. 4. If print jobs remain in the queue, check the connection between the HP printer and the computer, make sure USB is properly seated if its a USB connection, otherwise if it's wireless, make sure both devices are connected to the network. 5.If issue still persists,make sure the printer is set to online. 6.Manually clear the print queue, restart the comp then try printing again. &. If #6 doesn't resolve the issue.Restart the print spooler by clicking on Control Panel, then double-click Administrative Tools .Double-click Services--In the list of Services , double-click Print Spooler . The Print Spooler Properties window opens, then click Stop to stop the Print Spooler. Click Start to restart the Print Spooler.Click OK and restart the computer.Try printing again. 8. If print jobs from one specific software program are getting stuck in the print queue, the issue might be with the software program or the print driver.Close the software program from which you are trying to print, and then open it again.Print a document from the software program.If the print job gets stuck in the print queue again, try printing a document from Notepad to determine whether the problem is with the program or the driver.Repeat the steps earlier in this document to manually clear the print queue.Type a test message in Notepad and print it, making sure you select your HP product as the printer. If you can print the document from Notepad, but not from the software program, contact the software program manufacturer for assistance.If these steps resolved the issue , you do not need to continue troubleshooting. 9. Remove and Reinstall HP software, then try printing again. If these steps resolved the issue , you do not need to continue troubleshooting. If the issue persists , continue to the next solution. 10. A power reset drains the power from the product and returns to the same settings after restarting. A power reset is a common troubleshooting step, and you can perform one for conditions like print jobs getting stuck in the queue. With the product turned on , disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait at least 15 seconds.Plug the power cord back into the wall outlet.Reconnect the power cord to the rear of the product.If the product does not turn on by itself, press the Power button to turn it on. 11. If you have tried all of the preceding solutions in the order presented , and the issue is not resolved, try HP forums.
Mar 22, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
Printing blocked by a document showing being deleted
Sounds like a stuck document is in the print queue. Try to clear the print queue first before sending another print job otherwise it will just accumulate in the queue. The steps below will help you clear the queue.
Feb 21, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
The printer keeps on initialzing and not printing document
well this can be a memory issue or the motherboard of the printer. Try to do a reset on the printer. Its called NVRAM and will clear the memory completely. Turn the unit off and while off press and hold the green check and the orange cancel. Hold them down as you turn them on and wait until you get permanent storage init. Release the keys and wait until it get to ready (It might ask about language just press the check). Before trying to print again clear the print queue and try something that worked before or a new document (like a new word doc with a few letters)
Sep 02, 2010 | HP Color LaserJet 2600n Printer
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Printer Problem
Unless there is an issue with the cable connecting the printer, this is almost always software/driver related. A restart will usually fix it but if not, then try reinstalling the drivers completely. Also, after restart...test with a different document then whatever you last tried to print, do a test page or text from notepad.exe.
It can be the particular document as well and you don't want to waste a lot of time testing your printer if it is just a document issue.
Jul 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
18 people viewed this question
Seeker5211
Seeker5211
