Question about Bissell 3910 Bagless Upright Cyclonic Vacuum
My bissell 3910T won't stay upright. Is there a spring that may have fallen off?
There is a pedal low down (left rear of unit) that when depressed it unlatches and the unit can tilt but when put back upright, it does not spring back to latch and lock in. Is there a tension spring that may have fallen off?
Agent Don
  • 310 Answers
SOURCE: Foot pedal broken
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=629933
Foot pedal broken
Posted by Monte79 on May 28, 2008
I have Bissell Power Steamer Clear view IIII #3105403. I let someone borrow it (mistake #1) and he over extended the foot pedal that angles the upright during use. The pedal is still connected, but the power steamer is locked in the upright position. There is also a bit of dirty water in the bucket, and i cannot empty it because it's basically locked in now. HELP
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem with your Bissell, it sounds like he bent the handle release lever and you either need to bend it back or replace it depending on the level of damage to the item. Please feel free to contact the Bissell factory to see the best way to fix the problem, it is not an expensive fix however so contact your local vac dealer or get a referral from the Bissell factory for the nearest Bissell authorized dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
SOURCE: Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Posted on Jul 06, 2008
SOURCE: the foot release latch has broken or become unlatched on my uprig
I had this problem once before. The only thing I did was loosen the back 2 screws, take the release latch and just play with it until it catches, rea simple.
Posted on May 11, 2009
SOURCE: bissell 3595 handle release pedal spring(?) missing
I just fixed this on my Bissell PowerForce model #6594 vacuum myself. Woo Hoo for me. :-)
I called the local vacuum repair guy and he told me he'd repair it for me if I insisted but that since my machine only cost about $80 (a lot of money for me) it would not be worth the $40-$50 repair. I should just buy a new vacuum (from him I assume).
My machine works great so I sat down on the floor and after removing 5 screws and a little tinkering I got my machine apart. I had to take the brush and belt area off and then the upright part came off the base. Make sure you unplug your unit before working on it.
Next I could see where the Handle Release Pedal (HRP) on the bottom of the unit had been cracked. It's a molded piece that has a slight curve in it that allows it to spring back into position to hold the vacuum in the upright position or to keep the vacuum from going totally flat.
How it was installed I don't think they meant for it to be easily replaced but after using a screw driver on one side and a letter opener on the skinnier side I pried the molded houseing out from around the HRP just enough to let the it release. I did need a third hand for that part.
Posted on Jul 31, 2009
  • 54 Answers
SOURCE: My Bissell proheat 2x 8930-m
It's a detent handle release or release lever $8.95
Posted on Aug 28, 2011
Why won't my dyson d28 vacuum? I step on the foot and it won't tilt?
The manual is here, amongst other places:
Dyson DC28 Animal User Guide Around Page 4, as labeled in the manual, it shows the operator stepping a foot onto the lower unit and pulling the handle back. It's a common instruction for every Dyson upright I've looked at a manual for. Pull a little harder and it should tilt. Try moving it through the full range of motion a few times, and also make sure the lower click connector for the accessory hose if firmly seated at the bottom rear of the unit.
Good Luck!
Jul 14, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Self propelled high speed
If by "lever" you mean the step on rocker pedal at the rear of the unit, then we're talking about the same thing. If not, then I have no idea what lever would move to "D" or "I". When the pedal is depressed on one side it puts the drive mechanism into gear, when it's depressed the other side it moves the drive mechanism out of gear. It's about that simple, unless the pedal is broken inside the drive box, then nothing happens either way, usually. The only way to tell if it's really broken is to try it in both directions, if there's no drive in either side then there's a problem in the box. You'll need to take it to a qualified repair shop, not everyone can repair these drive boxes.
Nov 11, 2013 | Kirby G4 Bagged Upright Vacuum
I took my Dyson DC 25 Animal apart to clean it, and now the red foot pedal won't lock the vacuum into the upright position anymore. The trouble is the spring pin for the pedal popped out and I can't figure...
That spring thing goes where the pedal screws into the side. When 'facing' the dyson in the front, it's on the left side. The spring's circle part and short stem section goes into a divot area on the pedal. The other end is tensioned (braced) against some housing piece, but once you insert the spring part in the pedal end part, you should be able to figure it out from there.
This darned spring makes the pedal 'tensioned' to where it pops back up vs. flopping nonsensically.
Feb 09, 2011 | Dyson DC25 All Floors Bagless Upright...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
My floormate isn't picking up the wet water
Check the uptake tube. When you push the release button and bend the top of the unit towards you, you can see the tube coming out of the floor assembly. Mine split right there.
Jul 10, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell proheat turbo 2x upright cleaner -how do I reassmeble?
Yeah, it’s annoying that the manual doesn’t give more detailed instructions and drawings to help with this, because you do have to take the roller assembly apart sometimes to clean built-up carpet lint off the unit properly. If you don’t do this, I’d expect you’d have more problems.
I have a different model number Bissell Proheat than yours. Yours may have different parts or go together differently than mine, but I'll tell you how I do it on mine and you can try my way out and see if it helps you.
(In all cases where I use left vs. right or front vs. back, as when these terms are used with a car, I am facing the front of the Bissell. I am NOT behind the Bissell, where I would stand when cleaning carpet with it.)
Here's how I put it together. This takes much longer to describe than to do, once you figure out where everything goes and you get the hang of doing it!
Attach the left arm with the two silver rods (ONLY attach the left arm here-- leave the corresponding right arm, which looks like the left arm except it has no silver rods, off the bottom unit of the Bissell, for now) to the left side of the Bissell, with a silver screw with a built-in washer. The screw hole is on the back end of the arm and the arm dips down towards the front of the Bissell and holds the two brushes in position so that they can turn without striking the top of the underside of the Bissell or dragging on the floor.
Put a small silver washer on each long, silver metal post, where the roller brushes will go, and slide it all the way to the left.
Put the larger rubber belt around both metal posts, about halfway to two-thirds of the way down the metal posts.
Slide the brushes halfway down the metal posts and attach the larger rubber belt to the cog wheel on the left side of each roller brush. Then slide both roller brushes with the large rubber belt attached all the way to the left so that the cog wheels are against the inside of the left arm. As you move the roller brushes almost all the way to the left, you may be blocked from reaching the end until you carefully work the rubber belt around a plastic flange on the inside of the left arm, but do this and be sure the roller brushes are up against the inside of the left arm. Make sure the rubber belt is still on each of the cog wheels when the roller brushes are pushed all the way left. If you turn one roller brush, the other should turn, too, because of the belt attached to both cog wheels.
Put the small belt around the small cog wheel on the bottom unit of the Bissell behind the right end of the back roller brush, and also around the cog wheel on the right end of the back roller brush. (The right cog wheel on the front roller brush is the only one of five cog wheels without a belt, when everything is assembled correctly.)
Put a small silver washer on the right end of the silver rod passing through the back roller brush.
NOW attach the right arm, using a silver screw with a washer, to the middle screw hole on the right side of the bottom unit of the Bissell. The right arm should mirror the left arm, so that the two arms hold both roller brushes in position on the right side and straight across the bottom unit of the Bissell. It is normal for the roller brushes and arms to be able to flex up and down a bit, when everything is put together correctly. The built-in washers on the silver screws which attach the arms keep the arms and roller brushes in the generally correct position but allow them to flex.
Now using your fingers you should be able to slowly spin the roller brushes without the brushes contacting the top of the bottom unit of the Bissell and without dragging too low against the floor. Check one more time and be sure the belts are positioned correctly around four of the five cog wheels.
If everything seems right, attach the two side covers. These are not interchangeable; the left cover only fits on the left. The short black screw goes in the back screw hole, and the long black screw goes in front.
Then attach the front cover. It's important to be careful that the hooks on the front cover are inside the side cover holes designed to hold the hooks before trying to tighten the last screw through the tab on top of the front cover. If you aren't careful about this, it's easy for the front cover to be out of position or to break its tab.
Try powering up the Bissell and see if the rollers spin correctly. Remember that the handle must not be locked upright and the trigger must be depressed with the Bissell turned on before the roller brushes will spin. (Sometimes people complain that nothing happens with the unit turned on and the trigger depressed when the only problem is that the handle is in the locked upright position.)
May 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do you get the handle from the upright position
there is a pedal on the left side near the wheel press down and lean the handle back.sometimes you have to lean the handle forward while presing the pedal and then lean the handle back
Apr 23, 2009 | Kenmore 35912 / 35913 Progressive Upright...
The back wheel came off and i went to put it back on and the other wheel that connects to the mechinism/gear height ajustment that goes up/down with a spring in it came off as well. i have been looking for...
You do not need schematics, it is fairly easy. Clean and lubricate the teeth on the inside of the front wheel shaft assembly. Insert the spring into small pedal and place the pedal designated opening on the Kirby front fan casing with teeth facing out. Then take the wheel shaft assembly and put it over those teeth and onto the fan casing. Use two clamps and 2 screws to attach the shaft to the fan case. Need any parts - go HERE.
Good Luck,
Rocky
Apr 05, 2009 | Kirby G6 Bagged Upright Vacuum
How do I change the flilter on the sebo upright
Depends on the filter you're talking about:
The first filter is in the bag area- unhook and lift off the bin door, then bend down and flick your finger onto the left hand spring that locks the long cylindrical felt filter in place and lift upwards - this will loosen and unlock the filter from the base - put your hand at the back or front of the filter at the front near the base and pull towards you - the filter should then slide off easily.
Or it could be the motor filter you are referring to; push the pedal all the way down on the pedal release to put the X1/X1.1/X4/X5 into the lay-flat cleaning position, and push back the grille on top of the hood - you'll see a push finger mechanism there of which the grille will then be unlocked and can be picked up.
Nov 11, 2008 | Sebo X4 Bagged Upright Vacuum
Bissell 3595 handle release pedal spring(?) missing
Aug 30, 2008 | Bissell 3522 PowerForce Bagged Upright...
Bissell 3910 Bagless Upright Cyclonic Vacuum Logo
150 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
