Question about Eastern Tools & Equipment DG4LE 4000 Watt Diesel Fuel Generator
Need 120 to 240 switch KN25-202 25A250VAC - Eastern Tools & Equipment DG4LE 4000 Watt Diesel Fuel Generator
I need to wire a outside light and a inside light to one double toggle 2 way switch as separate switches for each light.
9k=Here is a double wall switch. Power into switch as with any switch, and each switch will operate separately. This type of switch is a common item in any big box store.
Jan 24, 2014 | Electrical Supplies
How to wire a four function switch
4-function switch can be 4 individual switches in a bank of switches, or it can be a combination of switch and timers.
Some timers need a neutral wire, while others, such as spring-wound timers do not need neutral wire: each of these items is wired separately.
Copy following link for switch illustrations, including 4 function switches.
http://waterheatertimer.org/How-to-wire-switches#gang
http://waterheatertimer.org/How-to-wire-timers.html
Jul 27, 2012 | Broan-NuTone FAN CONTROL SWITCH
Removal of ignition switch
remove the lower plastic cover that surrounds the switch unplug the switch remove the screws that hold down the switch you may need to turn the key a little while pulling off the switch assemble opposite way they you will need learn the new switch to the system you will need to cycle the switch to crank and leave it until the security light stops flashing repeat for 3 cycles then after the last time remove the key then start the car if possible keep a battery charger on the battery because if the battery dies during the learn procedure you will need to start over
Apr 13, 2012 | 2005 Chevrolet Cobalt
How to fix the dimmer switch on a 1992 Buick LeSaber does NOT Click on when I pull back on the same handle for wipers, cruse control & ect. Need a quick fix it will not pass Texas inspection and...
the dimmer switch is located on the steering colum about half way down . It is kind of hard to see .. there is a rod that runs from the turn singal handle down to the dimmer switch . it could be off or missadjusted . will need to check it might need a flash light to see it . the dimmer switch adjust with two little bolts i think they are 5/16 so they will need to be loosen to adjust the switch and rod or they will need to be removed to relplace the switch . i think the switch should be under 25 dollars if you need to replace it and should beable to be found at any local parts store
Mar 04, 2011 | 1992 Buick LeSabre
Want to bypass pressure switch to work when i need it.
I'm not sure what your question is. You can wire another switch (say a light switch) in parallel with the pressure switch. Then it will run either when you turn it on, or when the the pressure switch does, or when both switches are on. But it won't turn itself off. If you want to disable the pressure switch, you will need to take it out of the circuit.
May 19, 2010 | Electrical Supplies
Need to replace the light switch in my bathroom.
yes there the same type of switch,,just one is more up to date than the old one
Mar 28, 2010 | Leviton 1451-2ACP Grounded Quiet Switch
I need to change the bulb in the switch for the passanger side heated seat switch on my 2006 honda odyssey
There is no way to just replace the bulb. You need to replace the hole switch. The bulbs are molded in the switch when they make them. To get the switch you need to go to dealer for it.
Jan 12, 2010 | Honda Odyssey Cars & Trucks
I need to know how to open a port on a linksys ezxs55w switch.
I don't believe you can open a port on this switch. You need an actual router to be able to open ports. The switch itself is not routing anything, just acting as a switch. You will probably need to connect a router to be able to open/forward ports.
While the "no configuration required" feature seems nice when purchasing this switch, it unfortunately does not allow you to configure it when you do want to.
Dec 19, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Need foot switch for this machine.
What you need is 2 unlatched switches 1 for the stop start function and one for the drum fill function.
I bought mine from my local music shop for £15 ea
Apr 21, 2009 | Alesis Sr 16 Stereo Drum Machine
Eastern Tools & Equipment DG4LE 4000 Watt Diesel Fuel Generator Logo
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
