Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic EDTV loses signal
I have a Panasonic EDTV and it loses the signal and goes to snow at least once a day. It seems like it gets interupted for a few seconds (or more) then the pix goes back to normal and this starting happening when i switched to HDMI cable. The cable is a monster cable so its good quality and its not the cable box as i had 2 switched out and it still happened. Solve this
I have the same problem with a Pioneer but the satellite shows a good consistent signal. I also had issues with snow on the LNB. Perhaps the HDMI cables as you mmention.
Posted on Jan 27, 2009
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
We have a samsung plasma about 4 years old. once tv warms up the bottom half of the screen goes black. is this problem fixable
Check ur Caption functions?Tries turn off everythings involve captioning off or reset to factory setting.Still the same result must change the Main Tuner signal video board.
Jan 08, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have a Panasonic TX 15LT2 TV, after about 15
the small signal panel needs to be replaced.
[main module]
take you tv to a factory authorized service center..
Nov 09, 2009 | Panasonic TC-22LT1 22 in. LCD EDTV
Picture has snow
check the input cable or signal and insert it properly.
Sep 24, 2009 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
I have a Samsung SP-S4223 42in. EDTV.
This is called tiling and this happends because of a weak signal from whatever device you have hooked to it weather it be cable or a sat dish. Try checking and makie sure you have good signal to this. If this matter gets wrose then you would need a repairman. Thanks
May 24, 2009 | Samsung SP-S4223 42 in. Plasma EDTV
Screen goes black after 1-2 hours
You need to have your television tuner tested for faulty components. Your problem is caused by the components in you tuner overheating and losing functionality. The tuner need to be thoroughly test and repaired. You can reach Panasonic customer support at this telephone number. 1-888-843-9788. They should be able to tell you what the problem is and where to take it for repair. I hope this information helps you with your problem.
May 22, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Panasonic th-37pwd8uk hook up
Have you tried using the video out and audio out RCA jacks from the directtv receiver and inputting this signal into the composite video and audio inputs on your EDTV?
Jan 27, 2009 | Panasonic TH-37PWD8UK 37 in. EDTV-Ready...
Repair Akai TV
the snow is just because of poor quality signal
the signal coupler which is in the tv might be bad or your dish needs to be reset cause of the wind
Mar 12, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Records snow/static - intermittently
Intermittent problems like this really suck.
I have a simular problem on my Toshiba DVD recorder. Once in a while it just doesn't record anything at all.
Unfortunately, there really is no solution. It sounds like a glitch in the unit to me. Wether or not it's present in all the units of that model or just yours, only Panasonic knows for sure.
Feb 14, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
