Question about High Sierra Measuring Tools & Sensors
High Sierra Tahoe weather station manual
8050-58
LA Crosse manual for weather station 308-1414
Most LaCrosse weather station manuals are available here: http://www.meade.com/support/manuals/ or on the product page (see the Support tab). Using the search feature on the support page, I found three models which start 308-1414. Two of these differ in the color of the case of the weather station. Hover over the picture of any of these weather stations and click on the More button to go to their product page. The direct link to the manual for the 308-1414MB is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414m.pdf . This product page is http://www.lacrossetechnology.com/308-1414mb-weather-station/ . The manual for the 308-1414W/308-1414B is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414.pdf . The product page for the 308-1414W is http://www.lacrossetechnology.com/308-1414w-weather-station/ .
I hope this helps.
Jul 10, 2017 | La Crosse Measuring Tools & Sensors
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Need manual
I need to know the set up, lost manue
Apr 15, 2013 | Leeds 805058 High Sierra Tahoe InOutdoor...
1690-34bk manual
Lost my manual on how set this weather station.....please point my into the right direction
Jan 09, 2013 | Leeds 169034BK Affiliate 15 Inch Weather...
Honeywell weather station manual te657w
Hi i need the manual for the above is there some where u could upload the manual to and give a link thanks
Nov 25, 2012 | Honeywell Weather Forecaster with Heat...
No longer shows temp (indoor or out) or weather. Outside unit is still working and showing temp.
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
May 22, 2011 | Leeds 805058 High Sierra Tahoe InOutdoor...
Measuring Tools & Sensors Logo
186 people viewed this question
Top High Sierra Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a High Sierra Measuring Tool and Sensor Expert? Answer questions, earn points and help others
