Question about Magnavox ZV457MG9 DVD Recorder VCR
How to finalize a disc on a Magnavox ZV457MG9 Recorder
I have a Magnavox ZV457MG9 DVD recorder. According to the manual I should be able to select "setup" then "Disc Edit" and then "FINALIZE" in order to finalize my disc ... BUT ... the option to finalize does not appear. This makes no sense to me. I am using a Memorex DVD+RW. Am I possibly using the wrong disc? I need to finalize this so I can mail it to my granddaughter for use on her machine. Any help would be greatly appreciated.lution from experts
SOURCE: I would like to download
I found two:
The entire manual online (also has download link): http://www.manualowl.com/m/Magnavox/ZV457MG9/Manual/191523
The downloadable version: (It SHOULD work) http://download.m4c.magnavox.com/files/z/zv457mg9_f7/zv457mg9_f7_dfu_aen.pdf
This isn't much but it's something: http://download.p4c.philips.com/files/z/zv457mg9_f7/zv457mg9_f7_qsg_aen.pdf
Posted on Aug 23, 2011
SD Tech
  • 14553 Answers
SOURCE: Recording Error- can not record on this disc. E 4 54039000
Just one disc does this or more?
Posted on Apr 24, 2012
gopakumarg43
  • 75452 Answers
SOURCE: need manual for my magnavox rw/dvd recorder model # mwr1006
Try this link to download it.
Posted on Jun 01, 2012
gopakumarg43
  • 75452 Answers
SOURCE: user manual for magnavox rw/dvd recorder model #mwr1006
Try this link.
  • 5422 Answers
SOURCE: How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Posted on Jan 01, 2013
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I would like to download the manual for this magnavox ZV457MG9 vcr/dvd recorder machine as I can't find mine. Please send me a link I can use to do this. Thanks
I found two:
Aug 23, 2011 | Magnavox ZV457MG9 DVD Recorder VCR
Need a manual for magnavox dvd record/vcr zv427mg9
You can download the manual from the manufacturer's web site at
Jun 14, 2011 | Magnavox ZV457MG9 DVD Recorder VCR
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My disc records fine, plays great on the Magnavox, but no other player can read the disc?
You must finalize a disc before it can play on other machines. Please refer to your documentation for how to finalize a disc.
Jan 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Feb 15, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recorded dvd will not play
You have to finalize the disc. Get out of disc menu and press setup on remote. Select disc edit and finalize then it will play on other dvd players.
Aug 15, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox ZV457MG9 DVD Recorder VCR Logo
62 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
