Question about Whirlpool Dryers
No heat I already replaced the heating element
  • carpenterbra Jan 30, 2009
    The old heater was not bad. The line fuse and incoming power is there. There is poweer at the thermal cut off and high limit stat but they read differently when jump tested. I'm using a test light. the thermostat may be bad so I think I am going to replace all three because I'm just guessing at this point and don't want to have to make a third trip to the parts place.
  • carpenterbra Jan 31, 2009
    you know voltage varies slightly 110-120 for a normal phase so with that in mind I had power and that's most of what i needed to evaluate. It turned out to be the thermal cut-out which seemed to show 220+- on opposite sides . Ity's all good now thanks.
    Sniper:
  • 50 Answers
Was the old heater bad? check your fuses and /or circuit breakers fuses will show a break in the glass part, circuit breakers flip to off and then back on. some times breakers dont flip to blown section. if all o.k. test the terminal block where wire connects to dryer see if a terminal is blown. if o.k. chreck thermostats especially fuseable link inside back panel most likely fuseable link will be no good. if everything checks out youmay want to buy a repair booklet or call a repairman as the problem is very technical. good luck
Posted on Jan 27, 2009
  • mike murphy Jan 30, 2009
    before buying all thermowhy not go to radio shack or a similar store and pick up a volt/ohm meter probably for a lot less than the cost of the thermostats and you will find many uses for it in the years to come.a test light is good if you only want to check if voltage is present where as a meter set on ohms can tell you if the part tested has continuity which i'm sure you know means nothing is amiss with the particular part you are testing. one more thing that just entered my brain isyou say you have line voltage to the terminal block in the dyer, but do you have 115v at the red and white wires and 115v at the white and black terminals and 230v between red and black terminals? keep me informed if you wish, you sound like you pretty much know what your doing
Samsung DV422 No heat already replaced heating element
I would hate to ask a question and be left hanging, so I'll toss a couple of ideas your way. I'm sure you did already, but check your incoming power again. It is a 220vac input. If you have a voltage tester, make sure you have both 110vac phases. If you have power, since you changed everything else, my next guess would be the temperature selector switch. If I could see an electrical print, I'd tell you where to jumper it out. If your switch is in the " air fluff" setting, you will not get heat.
Sep 22, 2016 | Samsung DV422EWHDWR
Awz231 tumble dryer not heating
Check your heating element.
Aug 31, 2016 | Dryers
Why does my Bosch Washing Machine (Classixx 1400) no longer heat the water? I have already tried replacing the washer heating element.
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
Jun 10, 2011 | Bosch Classixx WVF 240S Front Load Washer...
Apparently the heat element has gone bad. Everything works, but no heat. It is only about 13 months old, could the heat element have burned out already and if so can a average repairman replace the part....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 22, 2011 | Samsung DV218AEW Electric Dryer
Toast cooks corrctly on one side and hardly at all on the oher. I have cleared all the crumbs out. It is the same whichever opening I use.
it means the other side has no heat to toast the bread!
The heating element might have been disconnected already, worst of all it is already burned!
try to contact the manufacturer to get the HEATiNG ELEMENT part or repair and replace the said part!
That'll solved ur probs!
Dec 01, 2010 | Prestige Appliances 50973 Toaster
Where can i buy a replacement heating element for my lay z spa heater
I got a new heating element off eBay, it was just a double straight line one like the one already in the metal tube (in the pump). It fit, i wired it up and it works!!
May 20, 2010 | NRS Infratech Single Element 61-1/4 inch...
Substitute heating element
Go to the local appliance repair parts store- they will have generic replacement elements and will likely be able to get you a right one for your dryer.
You should know if possible two things: model/serial number for your unit and length of the heating coil. (perhaps you've already taken it out)
Dec 14, 2009 | Dryers
No heat but already replaced heating elimate
Check the thermal cuttoff. It is located on the element. If it does not have continuity, replace it. Also replace the Hi-limit thermostat, also located on the element, and the operating thermostat, located on the exhaust. These two should cut off the heat before the thermal cutoff blows.
Nov 25, 2009 | Dryers
Dryer runs too hot.
Remove power from the unit. You want to use a multi-meter set on an ohms scale. Remove the wires from each terminal at the heating element. Check resistance to ground at the heater by putting one meter lead to the case of the heater, and the other meter lead to each terminal at the heater. It sounds as though your element has gone bad and is shorted to the case. The resistance should be infinite. If you read any resistance from the element to the case, replace the heating element. The no heat setting should be exactly that....no heat.
May 22, 2009 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
