Question about Toshiba DKT-3220-SD Corded Phone
How to change the Time on the LCD display??
I just need to know how to chane the time on my phone display.
  • 38 Answers
To change time #652 HHMMSS press # or redial to confirm
this will change the system time
Posted on Mar 01, 2009
How to Change Time on NEC Dterm Series E phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time.
Mar 14, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
Display problem
tray to change ribbon wire (Flexible cable) its often happen on phone with slide model.
May 19, 2010 | Sony Ericsson F305 White +512MB Unlocked...
How do i change the time display?
  • From the programming extension (usually 100), with the phone idle and handset in the cradle, press the FEATURE button
  • Press 9 #
  • Enter the hour (01-12) and minute (00-59)
  • Press the Recall Key to change the AM/PM Setting
  • Press the Hold Key and continue if you want to change the calendar setting.
  • Press SPKR or hang up. The correct time should display
  • You must change the time from a phone with administration priveleges. This is usually going to be the main phone, extension 100 or 101. That phone must have an LCD display to make these changes.
    Jul 22, 2009 | Lands Phones
    Cant change my sanyo 6650 mobiles incoming msg font
    here i hope this helps you Display Settings
    Changing the Text Greeting
    The text greeting can be up to 15 characters and is displayed
    on your phone’s screen in standby mode. You may choose to
    keep the phone’s default greeting (“Sprint”), or you may enter
    your own custom greeting.
    To display or change your greeting:
    1. Select > Settings > Display > Greeting > Custom.
    2. Enter a custom greeting using your keypad and press .
    (See “Entering Text”on page 39.) (To erase the existing
    greeting one character at a time, press .
    To erase the entire greeting, press and hold .)
    Changing the BacklightTime Length
    The backlight setting lets you select how long the display
    screen and keypad remain backlit after any keypress is made.
    To change the Main LCD or Sub LCD backlight setting:
    1. Select > Settings > Display > Backlight.
    2. Select Main LCDor Sub LCD.
    3. Select Always On, Dim Only, or a preset length of time.
    To change the Keypad backlight setting:
    1. Select >Settings>Display>Backlight>Key.
    2. Select Always Off or a preset length of time.
    Note: Long backlight settings affect the battery’s talk and standby
    times.
    Note: The Always On setting returns to the previous value the next
    time you turn on the phone.
    Your Phone’s
    Please rate this solution thanks...
    Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
    Change clock time.
    The XN120 I know is a PBX, so setting the time sets it for all phones connected to the PBX. The time can only be set on an XN120 system phone which has an LCD display (or a PC - see below). It's quite complicated - refer to setup guide such as
    http://www10.GIScafe.com/nl/newsletter_confirm.php?enc_email=ZGF2ZS5jb3ZlbGxAc2lnbWFzZXZlbi5jby51aw==&subscriber_key=5d4ff921b647525ca172f7fb11ae56b4
    Some of these PBX systems have TCP/IP network cards installed so the time can be set from the NEC PC-Pro configuration program run on a network connected PC.
    Nov 10, 2008 | Lands Phones
    Set Time DTH-16D-1 (BK) TEL
    Here's how you adjust the time:
    1. Press <TRANSFER>
    2. Press <CONF>
    3. Press *
    4. Press <TRANSFER>
    5. Press <CONF>
    6. Press #
    7. "CAT MODE" displayed on LCD
    8. Press <REDIAL or LNR/SPD>
    9. "COMMAND" displayed on LCD
    10. Press 02
    11. Press <RECALL>
    12. Press 2
    13. Press <RECALL>
    14. "02>2>Current Time" displayed on LCD
    15. Input correct time using military time (HH MM SS)
    16. Press <CONF>
    Dec 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
    I have sixteen button NEC Electra ELite Multiline Telephones in my office-
    1. Press <TRANSFER>
    2. Press <CONF>
    3. Press *
    4. Press <TRANSFER>
    5. Press <CONF>
    6. Press #
    10. Press 02
    11. Press <RECALL>
    12. Press 2
    13. Press <RECALL>
    16. Press <CONF>
    Nov 13, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
    The time on the LCD is wrong
    If you are looking at the manual for the phone itself this probably is not covered because the phone system stores the time, not the phone. I do not know which Panasonic phone system you have. Here is a helpful link to a page that contains time programming changes. http://www.tel-programmer.com/time_setting.html
    Nov 10, 2007 | Panasonic KX-T7630 Corded Phone
    How do I change the time on Avanti 3020 telephone?
    For the Avanti 3015 phone you have to
    1. push the feature button
    2. enter the number 82
    3. enter the time as follows
    4. Enter four digits for the current time (00 to 23 for hours and 00 to 59 for minutes).
      Enter two digits for the date (01-31)
      Enter two digits for the month (01-12)
      Enter two digits for the year (00-99)
      - The display shows the digits as you enter them - Press {SAVE}
      - The new time and date are displayed
    Sep 28, 2007 | Lands Phones
    Toshiba DKT-3220-SD Corded Phone Logo
    616 people viewed this question
    Top Toshiba Lands Phones Experts
    Oloyede Monsuru
    Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
