Question about HP Compaq Presario 6310US (DA201A#ABA) PC Desktop
Hard drive wont come out of compact presario 6310us
I have removed the side cover of the unit and the two side screws. The drive slides back alittle but will not come out. I can't figure out how to get the other side panel off of the unit.
  • 41 Answers
You need to take off the face of the computer. There are six plastic tabs inside the computer that you can press down to remove the face. Once it's off, you can slide the drive out the front.
Let me know if you have any other questions. I'll monitor this thread.
Jason
Posted on Jan 27, 2009
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
How do I take out the hard drive from my HP Presario F600 laptop? Thanks!
remove the cables > remove the battery at the back. Unscrew the screws in the corners of it, then remove the hard drive...
Jul 14, 2011 | HP Computers & Internet
I do have a problem with my presario M2000 Compaq laptop which whenever i open the laptop, it keep asking me password. Futhermore, my dvd rome cannot response to cd. can u help me. Tq
  1. Disconnect the power cable and any printers, monitors or other peripherals you may have attached your M2000. Lay the laptop face down on a table, with the front of the laptop facing you. Remove the battery by sliding the release latch to the left. The front end of the battery will pop up. Rotate the battery toward the back of the laptop to disengage it from the laptop base.
  2. Locate the hard drive on the right side of the laptop. Remove the two screws holding the hard drive cover in place and remove the cover. The hard drive will have a mylar tab on it to help remove it. Grab the tab and lift up on the left side of the hard drive until it disconnects from the motherboard. Pull the hard drive straight up to remove it from the hard drive bay.
  3. Remove the single screw holding the optical drive in place. Stick the end of a bent paper clip into the disk tray release hole on the optical drive, located on the front of the disk tray. This will eject the disk tray. Grab the tray and slide the optical drive out of the laptop base.
  4. Remove the memory modules. The memory compartment is located in the center of the M2000. Remove the two screws holding the cover in place and remove the cover. Use your fingers to spread the latches on the sides of the memory modules and slide the modules out of the sockets.
  5. Remove the mini PCI card by first removing the last cover on the bottom of the M2000. Remove the screws on the cover and remove the cover to reveal the mini PCI card. Disconnect the white and black wireless antenna cables from the card. Spread the latches on the sides of the card and slide it out of the socket. Disconnect the antenna cables from the clip attaching them to the laptop base.
  6. Remove the keyboard cover and LED board by first removing the two screws in the battery bay. These hold the keyboard cover in place. Flip your laptop over and open it up. Slide a flat-head screwdriver into the notch behind the "F1" key to unlock the keyboard cover. Do the same thing at the "F5," F11," and "Insert" keys. Pull the cover up to remove it. The LED board is under the cover. Disconnect the data cable from the motherboard and remove the two screws holding the board in place. Remove the board.
  7. Remove the keyboard by first removing the four screws holding the keyboard in place. Lift the back end of the keyboard up and tip it over so it is resting face down on the palm rest of your M2000. Disconnect the data cable from the motherboard and remove the keyboard.
  8. 8 Remove the display panel by first disconnecting the video cable from the motherboard. Disconnect the wireless antenna cables from the clips attaching them to the top cover of your laptop. Remove the six screws holding the display panel in place. Lift the display panel off of the laptop base.
  9. Remove the base enclosure by removing the three screws on the top of the laptop connecting the top to the base enclosure. Flip the laptop over and lay it face down with the front toward you. Remove the 18 screws holding the base enclosure in place. Lift the rear end of the base enclosure up until it comes free from the laptop. Once it's free, slide it back to remove it.
  10. Disconnect and remove any remaining components including the speakers, Bluetooth module and USB card. All of them are removed by the same procedure. Disconnect the cables from the motherboard and remove any screws holding the components in place. Lift the components straight up to remove them.
  11. Disconnect the fan cable running from the cooling unit to the motherboard. Remove the three screws holding the cooling unit in place and lift it straight up to remove it. To remove the CPU, turn the locking screw counter-clockwise until it clicks. Grab the CPU by the edges and lift it straight up. Put the CPU in an antistatic bag for safekeeping.
  12. Remove the motherboard by first disconnecting the touchpad cable and remove the five screws holding the motherboard in place. Lift it up by the left side and remove it from the enclosure.
  13. please comment on these solution by saying how helpful.rating or voting.
Dec 24, 2010 | Compaq Presario M2000 Notebook
How do i remove my hard drive on my ps3 unit?
If it is an older type PS3 (Phat) on the left hand side of the console there is a small plastic cover. Using a small flat blade screwdriver, carefully prise one end of the cover outwards. There is a small cut-out on one end where the screwdriver goes. When you have this cover removed you will see a blue cross head screw. Remove this screw. You will also see a small wire clip that is attached to the side of the hard drive caddy. Pull this clip outwards. Carefully take hold of the clip and slide the hard drive towards the front of the console. The hard drive will then come out of the side of the console.
If you have a PS3 Slim the procedure is slightly different. On the bottom of the console there is a small flip out cover. Carefully remove this cover and there will be a blue cross head screw. Remove the screw. Now look below the slot where you put your discs. There is another plastic cover. Slide this to the right and remove it. Behind that cover is your hard drive. Flip the metal clip down and pull the hard drive out.
Hope this helps!
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
How to remove HDD in compaq presario sr2030nx
After removing the side cover, you will notice 4 black tabs behind the front bezel under the hard drive, bend these back just enough to let the front cover release at the bottom, then press the green square at the top to release the front plastic bezel. After you carefully pull the front off, you will need to remove the cables [power and IDE] pull up on the green tab that locks the guide screw on the hard drive and push it forward out of the case
Dec 11, 2009 | HP Compaq Presario SR2030NX PC Desktop
Compaq presario cq40 how do i remove the hard drive
Hi..
If you want to remove hard drive of your unit. Be sure that do you have little idea to do it with your own. You need to remove first the screw of your unit to open the back cover. Once you are already open the cover, you can remove the hard drive slowly.
Regards
ICmanServer
Aug 12, 2009 | Compaq Presario C700T Notebook
Compaq presario sr1330nx cover removal
There are two Phillips-head hex screws on the back of the tower. After you unplug everything, remove those two screws and slide the side panel out toward the back, then lift it off. Compaq has a manual online if you need other things after you get the panel off. Here's the link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00595250&lc=en&dlc=en&cc=us&lang=en&rule=23078&product=443740
Feb 08, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
Dec 02, 2008 | Compaq Presario 5000 PC Desktop
HP Compaq Presario 6310US (DA201A#ABA) PC Desktop Logo
110 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
