Question about Olympus Camedia C-50 Zoom Digital Camera
How can I set my option as 'default'?
Could anybody suggest me why... I open the cover... lens come out... I press 'OK'... menu comes out... choose 'mode menu'... choose 2nd tab 'picture'... press right arrow... choose 'image quality'(at this moment, default is HQ)... press right arrow ... choose 'SQ2'... press right arrow again... choose '640x480'... press 'OK'... press 'OK'... press 'OK'... close the cover... open cover again... the picture quality goes back to 'HQ' again as default! How can I set my option as 'default'? Many thanks!
    Genius:
  • 2,985 Answers
This could be a firmware problem Tell Olympus Tech support team
Posted on Jul 21, 2007
SOURCE:
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
I have a sony cybershot DSC-W120 (silver). When I power on the camera, the lens will not open? I am able to only review photos I have previously taken. What can I do to fix it?
If the Lens Mechanism is stuck the lens in the Camera will not open due to the malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
May 09, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My DSC-T10 Sony Digital Camera fell down and now the new pictures taken are coming Blurry (hazy). My old pictures in the memory stick shows perfect. Please advise what could have happened.
Based on the information you've provided, it seems that the Lens Mechanism of the Camera is damaged when it fell down. The Lens of the Camera is not focusing properly while capturing the images. As the issue is with the lens mechanism, the previously captured images are displaying normally. I suggest that you try resetting the Camera and check if the issue can be resolved.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Apr 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
DS-W370 lens the lens of the camera are out and i get a message to turn off the camera and try again but never worked
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Main Settings Menu of the Camera to OK. (Menu-->Settings-->Main Settings-->Initialize-->OK.)
Thanks for using FixYa.
Jan 10, 2011 | Sony Cybershot DSCW370 Digital Camera
How do I reset. I have pressed a button and I now have a grid, which I dont want. I only use the tulip sign and the x1 Help. Many thanks.
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd960menupress.jpg 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd970reset.jpg 4. Select [OK] and press funcseticon.gif. sd970resetall.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language], [Video System], and [Time Zone] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • The image registered as [Start-up Image]
Aug 02, 2010 | Canon IXUS 960 IS Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Zoom lens won't come out
If the lens will not come out, i need you to try this steps first before sending it in for SVC.
Improper battery connection might be the reason why there is not enough power for the lens to come out and open.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just set the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
About the warranty, basically you do have a 1-year Limited Manufacturer's warranty and it will start from the date of purchase. And if that expires, there is a usual charge of about $50-60. You'll be seeing the payment upon the creation of the online service request through www.samsungcamerausa.com and just click on Customer Service then Option 2.
Hope this works.
Dec 31, 2007 | Samsung Digimax S630 Digital Camera
Can't set my option as 'default'.
This is the second time that this query has come up in the last few minutes. It is beginning to seem as if it is a firmware problem Olympus Need to know about this Get on to technical support
Jul 20, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Olympus Camedia C-50 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
