Question about Vizio M3D550KD 55-Inch 240 Hz Class Theater 3D
Green lines appearing in black areas of 2week old vizio m3d550kd HDTV
Green vertical lines appearing in black areas of picture during HDTV broadcasts or DVD/bluray movie viewing
3 Suggested Answers
gopakumarg43
  • 74136 Answers
SOURCE: Why does my 26" Vizio TV have green vertical lines?
The fault is with its T'Con board.
Posted on Jun 10, 2012
gopakumarg43
  • 74136 Answers
SOURCE: How do I fix the vertical green lines on my Vizio 26
Check and replace T'Con board.
Why no answers for thin black lines on panel of vizio M3D550KD 55 inch tv
Of course it can be repaired. Do U wanna spend the money?
The circuit board that is responsible for vertical deflection has an intermittent condition responsible for the anomaly. If you locate the board you might want to check for the signs of a faulty capacitor.
If all looks dynamite, checking for a bad cap can be an ordeal and maybe the best way to go is simply replace the board in question.
Jul 13, 2015 | Vizio M3D550KD 55-Inch 240 Hz Class...
Vizio e500ar
If any colors (red, green, or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
Connect the LCD display to another computer.
Aug 01, 2014 | Vizio E500Ar 50 Class Lcd Hdtv - 1080P,...
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
How do i fix a picture problem on a Vizio VF552XVT?
not a do it yourself repair--one or more boards are possible.
Jun 26, 2012 | Vizio VF552XVT 55 in. LCD HDTV
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
Vizio M3D550KD 55-Inch 240 Hz Class Theater 3D Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
