Question about William Bounds Rita Stainless-Steel Mill 03707 Grinder
William Bounds Pepper Mill no longer grinds peppercorns
Our $70 Wm Bounds pepper mill is 5 years old and no longer grinds. Are there replacement parts, if needed. Or, what else could be wrong with it?
  • buckfam Feb 26, 2009
    I have the same problem, a 5+ year old stainless grinder from Wm Bounds. I called them and was told my grinder has a lifetime warranty and can be returned to their "repairs" department. The grinder would then either be repaired or replaced at their discretion.
    Hope this helps,
Tip
How to Open to refill a Reusable Acrylic Pepper & Salt Mill
Hello. This is about opening an acrylic pepper and salt mill or pepper grinder so that you may refill this kitchen utensil. One will usually find that the chrome knob on top of the pepper mill is used to open the pepper mill can be too difficult to open, because one cannot grip the chrome knob on top of the pepper mill to open. I am going to offer three different options for opening a pepper mill:
1) Use a pair of work gloves with specialize dripping material on finger tips. Hold top bulb while turning chrome knob counter clockwise.
2) A small nut wrench with cellophane tape on chrome knob to above marring chrome knob.
3) Get a wrench and a towel. Fit folded towel in jaws of wrench and place towel and open wrench on chrome knob and turn counter clockwise. Practice on a pine dowel to know appropriate pressure to use to avoid marring the chrome knob. If you can replace the chrome smooth knob with a grip friendly knob, if possible.
Finally, do not over tighten knob just finger tight.
on Feb 28, 2017 | Kitchen Appliances - Others
How do I fill with pepper
On most pepper mills, some part of the upper half usually unscrews, and the 'top' and 'bottom' can be separated. The bottom part will have a 'reservoir' in which the peppercorns should be placed, to eventually be ground.
Apr 05, 2014 | Bodum The Furniture Store Bistro Automatic...
I took off the cover on the bottom to add more pepper, but now I can not replace it. Its like the screw isn't long enough to screw back in
Hold it upside down and shake it so that the peppercorns get out of the way. They are making it so the screw doesn't serm long enough
Jan 13, 2014 | Cole & Mason Cole and Mason Keswick...
How to load peppercorns into trudeau 0716840
I found the following webpage on your grinder: www.shoptrudeau.com/v/vspfiles/images/instructions/0716840.pdf
Just in case the link doesn't work, it looks like the top (salt) part just pulls off the bottom, pepper grinder part. With the top off, there's a hole to pour the peppercorns into.
Jan 20, 2013 | Trudeau 0716840 Click Combo Pepper Mill...
How do I take care of my Olivier Roellinger pepper mill?
I found this link to their website and got some tips about cleaning and taking care of my pepper mill http://fantes.com/peugeot-pepper-salt.html
Jul 16, 2012 | Peugeot Olivier Roellinger Pepper Mill, 5...
What kind of peppercorns can you grind in an Olivier Roellinger Pepper Mill?
You can grind all types of peppercorns inthe Mill. Black White or Mixed.
GEtting the pepper corns in?
go to their website,it should be on the box it came in,and go to customer support,there should be a section on the page for manuals and info.
Dec 06, 2008 | William Bounds Rita Stainless-Steel Mill...
Coffee Makers & Espresso Machines Logo
1,014 people viewed this question
Top William Bounds Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a William Bounds Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
