Question about Alpine CDE-9881 CD Player
How to set clock
Need to set clock
How do I change clock in 2007 Mazda r
Hold Clock to get it in the set 12/24, tap Set to move to 12hr, tap clock to move to the hour, tap set to get to the right hour, tap clock to move to the minute, tap set to get it to the right minute, tap clock to back out of it.
Mar 09, 2015 | Mazda Cars & Trucks
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    Need to set clock on oven
    Instructions
      • 1
        Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
      • 2
        Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
      • 3
        Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
      • 4
        Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
    Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
    Mar 19, 2011 | Ovens
    CANNOT RESET CLOCK
    1) Press SOURCE and hold it until the unit turns off.
    2) Press AUDIO and hold until clock appears in the display.
    3) Press AUDIO again to display the setting u need to configure.
    - when u found clock, press < or > to select the segment of the clock display you wish to set.
    - press /\ or \/ to set the clock.
    - press BAND or hold AUDIO when finish.
    YBC (/\)
    Apr 27, 2009 | Car Audio & Video
    I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
    To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
    Apr 07, 2009 | Microwave Ovens
    Need to change the date and time
    You’ll need to set the clock so that it can
    announce the day and time that each
    message is received. Press "Play/Stop" to exit
    Setting the Clock at any time.
    1 Press and hold "Clock" until the
    Message Window displays C, and the
    default day is announced.
    2 To change the day setting, hold down
    "Memo/Repeat" or "ANNC/SKIP" until the
    correct day is announced. Then
    release the button.
    3 Press and release "Clock". The current
    hour setting is announced.
    4 To change the hour setting, hold down
    "Memo/Repeat"or "ANNC/SKIP" until the
    correct hour is announced. Then
    release the button.
    5 Press and release "CLOCK". The current
    minutes setting is announced.
    6 To change the minutes setting, hold
    down "Memo/Repeat" or "ANNC/SKIP" until the
    correct minutes setting is announced.
    Then release the button.
    7 Press and release "CLOCK". The new day
    and time are announced.
    To check the clock, press and release
    "Clock".
    Nov 26, 2008 | AT&T 1717 Digital Answering Machine
    How to set time
    http://www.emersonradio.com/owners Copy this web link and paste it into the address bar of your browser. The link will take you to the Emerson customer support clock Radio Owners manual directory. Here you can find you Type of radio and open the link and find you model. Open the model link and then you can follow the instruction given in the manual to set the clock. I hope this information helps you with your problem.
    May 09, 2008 | Emerson Smartset Clock Radio
    Setting the time
    On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory.
    Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
    The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
    The third is just the brightness.
    Now, to set the time itself:
    1 - Turn the clock face back up to where you can see it.
    2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
    Good Luck!
    Mar 16, 2008 | RCA RP5420 Clock Radio
    Setting Clock
    when you press time/wake the first time the 1 for alarm clock is flashing... if you need to set this time use the arrows, if not press time/wake again; the 2 for alarm clock is flashing... same if you need to set use the arrows, if not press time/awake again and a clock appears at the left hand corner, here you can set the clock by using the arrows... good luck! you continue in this fashion...
    Mar 04, 2008 | Audio Players & Recorders
    Setting the clock
    Here is a link to the manual: http://www.docs.sony.com/release/MHCGX20.PDF The instructions for setting the clock are on page 10. You will need the remote in order to set the clock.
    Mar 13, 2007 | Sony MHC-GX20 CD Shelf System
    Alpine CDE-9881 CD Player Logo
    23 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
