Question about Health-O-Meter Health & Beauty
I changed the battery on my health o meter hdm560dq9-05p and now it has an f error code
Error code 9 accu check meter Replaced battery still error 9. Also, strips are in date.
The only way to tell that the new battery is good is to test it with a volt meter. There is no way to tell how long a battery sat in a warehouse before it was moved to a store and sold.
Feb 24, 2017 | Health & Beauty
Accu Check Active showing Trouble E-1
The electronic error code refers to either
  1. your glucose level may be extremely high or a meter or a test strip error has occurred.due to insufficient blood sample on the test strip.
  2. A used test strip was removed and reinserted.
  3. The test strip may be damaged or not properly inserted
Try turning the meter off and on or take the battery out for a few seconds and try testing glucose levels again. In any event, check your meter's manual; if unavailable- you can download an electronic version of the manual from the manufacturer's web site; or some meters you can browse the info from your meter's screen menu.
Other options, replace the battery with a new one or perhaps your meter has met its end-of-life usage.
Be well!
Feb 12, 2017 | Active Health & Beauty
My healtho meter scale says errl and won't reset.I put new batteries in but still get the same error
Underneath the scale there should be a tiny hole marked R or RESET.
Straighten a paperclip and press it into this hole for five seconds and that should do the trick.
If not, try this again but with the batteries removed.
Replace the batteries and switch on.
Apr 13, 2015 | Healthometer Health o meter HDM691DQN 95...
What are the error codes for Accu-Check Glucometers
E5 codekey expired which means that the test strips or out of date and no longer any good. You get a new codekey with a new can of test strips. A pain, I know.
E1 Re Insert test strip
E2 Incorrect code key
E3 Extremely high reading
E4 Not enough blood on test strip
E6 Control Solution too soon?
E7 Electronic error
E8 Temperature too high
E9 Change Battery.
May 13, 2014 | Accu Chek ACCU-CHEK Aviva Meter
Health o meter-HDM562DQ-18, replaced battery, want to reset, no instructions.Help!
just inside the battery compartment, where the battery door latch goes, its about 3/4 on an inch down.
Jun 29, 2009 | Health-O-Meter Health O Meter HDM520KD 18...
Health & Beauty Logo
51 people viewed this question
Top Health-O-Meter Health & Beauty Experts
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
richie46
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
