Question about Jabra BT8010 Wireless Headset
Earhook design is not dependable
My earhook keeps falling out of it's socket on the headset. Each time it falls out it gets a little easier to come out the next time. shouldn't the earhook attaching socket hole have some sort of capture indent in it to hold the earhook piece in place?
  • Anonymous Jan 17, 2009
    Same problem, contacting jabra
  • edwardvan00 Jan 20, 2009
    It seems one earhook of the two is too flexible to be able to stay on your ear. The other one is more stif and holds to your ear a lot better. It seems a better design or a fixed earpiece would have been better. I'm calling Jabra tomorrow to see if they will send another ear hook. THe device itself is nice, only if it would stay on my ear.
I called Jabra and they immediately mailed a new earhook to me... I had it in my mailbox in about a week. Everything seems to work a lot better. Chalk one up for great customer relations from Jabra...Not many questions asked other than where to send it.
Posted on Mar 13, 2009
I own this headset as well.
I found the best thing is to not bend the earhook too often or they the metal wire inside will break and to offset the earhook from sliding out of the post due to the rubber expanding is to...,
Are you ready for this , rough solution but works is to wrap a small piece of chew gum around the hook at the very end but not too much that it comes above the edge of the insert
It really works though not permanent but it works for a long time
Posted on Jul 29, 2009
Question: How long have you had it? If you're still within the first 30 days of purchase you can return it for a new one. If you're outside the 30 days, call Jabra. I don't even own one yet but I've called them twice for product info and each time they were more than courteous in answering my questions. I've read other reviews where Jabra has worked with customers even to the extent of replaceing the device. Hope all goes well! By the way, how do those ear loops fit? I read one review that said they weren't comfortable.
Posted on Jul 28, 2007
SOURCE:
Top tray wheels keep falling off
I feel for you! I have been tortured by the blasted wheels falling off every time I go to put something into the dishwasher, or want to empty it. To add to it all, this part is no longer available to replace, which I need to do as one of the clips finally snapped off. It is a highly frustrating design flaw in this machine.
Feb 25, 2014 | Baumatic 23 in. BDW5 Built-in Dishwasher
My Earhook book and got seperated from the device. Device works properly but without earhook its of no use. Suggest if I can replace only the earhook
If you still have the ear hook you can find simple supplies at your local dollar store. I suggest adhesive putty. Once you have the ear hook back in place wrap the putty in tape or another type of material to prevent the putty from getting in your hair.
Feb 28, 2011 | Jabra BT125 Headset
The problem is we cant bloody find any. can you tell us where in New Zealand we can get some earhooks.
Ear hooks are easily found on ebay.
Jabra Replacement Earhook BT125 BT135 BT150 BT8010
put the underlined info in the search on ebay and it should take you right too it.
Jan 12, 2011 | Jabra Bluetooth Headset with Adjustable...
Where to find Jabra BT8010 earhook
Contact the company on website WWW.jabra.com. they are 10.95 plus s/h and you get 5.
Jan 29, 2010 | Jabra BT8010 Wireless Headset
The spindle with the chuck attached keeps falling out of my drill press. I can push the spindle (arbor shaft) up into the machine, but it later falls down. How do I fix this?
get something like brake clean and spray both parts the shaft and internal socket and then wipe with a paper towel. Next put the shaft into the socket and "tap" into place with a block of wood on the drill chuck with the jaws retracted. You might have to "tap" a little hard if you know what I mean but this will seat the tapers and you should not have a problem for a while.
Nov 16, 2009 | Drills
Earhook for Jabra BT350 Bluetooth
try using a large elastic band to "pin" the headset to your ear
Mar 08, 2008 | Jabra BT350 Bluetooth Headset Headset
Loose on ear
Had the same issue with a Motorola HS820. Motorola technical support was clueless. I finally detached the earhook as per the instructions for switching from right to left ear use. Soaked the earhook in a mug of boiling water (caution: boiling water can burn you) until it was soft and flexible, then bent the hook into a tighter curl, then held it that way under a cold stream of water until it set in the new, tighter shape. Replace earhook on headset. You may need to repeat this procedure from time to time.
Dec 30, 2007 | Motorola Mobility H500 Wireless Headset
Broke the ear hook for the Motorola h500 bluetooth headset
The ear hook on my H500 broke as well.  I called Motorola (866-289-6686) and they are mailing me a replacement.  Even though This bluetooth has a 1-year warranty.  I purchased mine in Jan. 2007 and was covered but the rep didn't verify anything regarding the purchase date so even if you're outside of your warranty, you might still give it a shot.
Sep 14, 2007 | Motorola Mobility H500 Wireless Headset
Jabra BT8010 Wireless Headset Logo
280 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
