Question about Olympus Camedia C-50 Zoom Digital Camera
Can't set my option as 'default'.
Could anybody suggest me why... I open the cover... lens come out... I press 'OK'... menu comes out... choose 'mode menu'... choose 2nd tab 'picture'... press right arrow... choose 'image quality'(at this moment, default is HQ)... press right arrow ... choose 'SQ2'... press right arrow again... choose '640x480'... press 'OK'... press 'OK'... press 'OK'... close the cover... open cover again... the picture quality goes back to 'HQ' again as default! How can I set my option as 'default'? Many thanks!
  • Anonymous Mar 18, 2014
    the enddosc ope is stuck on the default setup on main menu and will not do any thing or show images - it was working ok and i have tried disconnectiong from and switching off but it not even turn off - can youhelp regards phil.
    Genius:
  • 2,985 Answers
This is the second time that this query has come up in the last few minutes. It is beginning to seem as if it is a firmware problem Olympus Need to know about this Get on to technical support
Posted on Jul 21, 2007
SOURCE:
Make google my default page
When on line hit the tools menu, hit internet options. hit the general tab, in the home page box type in www.google.com press apply, then hit the tab menu, under the when a new tab is opened choose your first home page, then press OK, press apply again then OK.
Oct 31, 2013 | Computers & Internet
I have a sony cybershot DSC-W120 (silver). When I power on the camera, the lens will not open? I am able to only review photos I have previously taken. What can I do to fix it?
If the Lens Mechanism is stuck the lens in the Camera will not open due to the malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
May 09, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
How to reset a brother mcf-7420 printer?
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  2. From the main BRAdmin screen double click the appropriate printer.
  3. Enter the print server password (The default password is "access").
  4. Click the Control tab
  5. Click the Restore Factory Defaults button
  6. Click the OK button when you have read the warning message.
  7. The print server will then reset back to its default values.
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
  6. The print server will then reset back to its default values.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete. please rate it
Nov 29, 2010 | Brother MFC-7420 Printer
How do I reset. I have pressed a button and I now have a grid, which I dont want. I only use the tulip sign and the x1 Help. Many thanks.
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd960menupress.jpg 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd970reset.jpg 4. Select [OK] and press funcseticon.gif. sd970resetall.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language], [Video System], and [Time Zone] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • The image registered as [Start-up Image]
Aug 02, 2010 | Canon IXUS 960 IS Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
PCV-RX580
ok, you press F2 or F3 to enter into the bios setup.
Thanks
Oct 27, 2009 | Sony VAIO Digital Studio PCV-RX580 PC...
é comes up when i try to press the key for a slash
I believe you have the wrong keyboard input language installed as the default language.
If you are using Windows Vista...
1. Open the Control Panel. (Classic View)
2. Click on the Regional and Language Options icon.
3. Click on the Keyboards and Languages tab.
4. Click on the Change keyboards button.
5. To Select a Default Input Language, under the Default input language section, click on the drop down menu and select a language (English (United States) - US?).
6. Click "Ok" and try your keys.
If you ar eusing Windows XP...
3. Click on the Languages tab.
4. Dlick the "Details" button.
5. In the windows that opens, choose the "Settings" tab, and change the "Default input language to "English (United States) - US", and make sure in the window below, the Keyboard is set to "US"
6. Click "Ok" twice and try your keys.
Sep 19, 2009 | Acer Aspire 4720 Notebook
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Zoom lens won't come out
If the lens will not come out, i need you to try this steps first before sending it in for SVC.
Improper battery connection might be the reason why there is not enough power for the lens to come out and open.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just set the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
About the warranty, basically you do have a 1-year Limited Manufacturer's warranty and it will start from the date of purchase. And if that expires, there is a usual charge of about $50-60. You'll be seeing the payment upon the creation of the online service request through www.samsungcamerausa.com and just click on Customer Service then Option 2.
Hope this works.
Dec 31, 2007 | Samsung Digimax S630 Digital Camera
This could be a firmware problem Tell Olympus Tech support team
Jul 20, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Olympus Camedia C-50 Zoom Digital Camera Logo
55 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
