Question about Coleman Heating & Cooling
Does coleman 3400A816 have 2 speed motor
Does the sequencer also contol blower motor speed?
dcp2
  • 63 Answers
SOURCE: Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Posted on Jan 28, 2008
  • 43 Answers
SOURCE: heater speed contol resistor location.
Look behind the glove box the blower resistor will be close to the firewall on the passenger side......
Posted on Apr 03, 2009
  • 32 Answers
SOURCE: coleman rv ac blower motor starts then slows and
Yes it sound like it is the motor. Is the unit on top of the RV? If it is then it is more likely the motor since it is in the elements
Posted on Sep 01, 2009
  • 55 Answers
SOURCE: change fan motor coleman mach rooftop air
What are you asking? Do you have the replacement motor yet?
Posted on Mar 22, 2013
airjer995
  • 5332 Answers
SOURCE: 1983 Chevrolet C10 Silverado: The AC compressor and heater blower motor fan will not come on.
The brown wire at the speed switch is the power wire. Powers is then directed to the blower motor resistor throught the orange, lt blue and yellows wires. The blower motor receives power through the orange wire. Check for power at the fuse with the key on. If there is no power the problem could be the ignition switch or the wiring in between the switch and the fuse block
Posted on Apr 05, 2013
Coleman evcon ignites but hardly any heat at vents blower motor workin constantent running
Dirty evaporator coil, dirty air filter, weak blower motor windings, weak blower motor capacitor, wrong blower speed, leaking or broken ductwork, uninsulated ductwork, gas valve pressure needs adjusting(low fire)? Might be any or all of the above.
Nov 02, 2017 | Coleman Heating & Cooling
Coleman evcon EB15A heat is stuck on. Thermostat disconnected to make sure it wasn't the issue. Stays on and heat blowing. What can I try?
It sound like your first stage sequencer is stuck in the 'on' position Shad. Usually the first stage is responsible for turning on the blower on low speed while energizing the first 5 kw of electric heat.
The problem you describe is typical of 'stuck' contacts within the sequencer.
No field service to the sequencer, replacement is necessary. Of course without actually seeing your furnace, this is just a resonably educated guess.
Apr 15, 2015 | Coleman Heating & Cooling
Heating elements keep coming on and off after blower turns off
Yes your sequencer is the switch to energize the elements & sometime the low speed on the blower motor. It completes the 240 volts going to the elements. The sequencer turns the elements on in stages as well as the blower, & most sequencers have numbers on the side to tell what thermal disk turns on first. The blower, & one element should be wired on the 1 & 2 terminals (this turns on first when the sequencer coil is energized & shuts off last when the coil is de-energized). If any of the thermal discs are stuck closed, this will constantly energize the element on that switch.
Dec 04, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Apr 05, 2013 | Cars & Trucks
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
I have a 1996 ford crown victoria and the blower motor only works on high?
the temp contoller resistor in the Ac box tha operates the blower speed contoller is burnt out and needs to be replaced
Jan 22, 2010 | 1996 Ford Crown Victoria
Can't unlock the control panel
Usually in sequence... Program-Mode-Temp Down... Or temp Up to lock
May 24, 2009 | Coleman (5040B750) Patio Heater
Reduce blower speed
Motor speeds on the blower are always remember black is high, blue in med. and red is low sometimes blowers are 4 speeds but the main colors are the black blue and red. Now where to change locate the wires coming from blower to a box or control board. control board has setting for heating and cooling speeds for the blower. You might see blue on heating which would be medium speed so take the red off park terminal and change places with the blue. Now if you have a fan control switch it looks like a dail in the middle of the furnace with numbers on the face with pointers set at the numbers. follow the wires from there to the electrical box and open box. find color of blower and switch be sure to cap off the wire you change. Wire nut would be good.
Nov 19, 2008 | Coleman Propane Forced Air Heater...
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
