Red green lights flashing repidly on lennox elite furance cirurit board
5 Suggested Answers
  • 96 Answers
SOURCE: furance is not fireing up
sound like high limit switch or high presure switch
Posted on Nov 14, 2008
  • 472 Answers
SOURCE: my furnace is flashing 21
not sure what 21 is ,but if you are getting acode normally the code comments are on the door or the manufacture lable to tell you what they are...
i can tell you the operation and maybe that will help you out...
the unit should start off with the enducer draft motor small motor in furnace that pulls all the stale air out..then the negative pressure switch activates which should have a hose coming from the enducer draft moto to the pressure switch..once the pressure switch closes it sends power to the ignitor and the ignitor should glow once it gets hot a milivolt current is sent back to the gas valve and it opens up and fires...after it fires you should have a flame sensor small metal rod in the direct path of flame that keep sensing the flame and sends signal back to board.... unplug unit and watch it start where is it failing or in what part of the operation does it flash a code....
Posted on Jan 03, 2011
tunde007
  • 2382 Answers
SOURCE: Model RRMA-AO42JK1OE Furance won't start. Red
Hi, is there 3 blinks followed by a 2 second pause? if so then you have a open limit switch on the furnace, a limit switch opens when the heat exchanger gets too hot. If you have a meter check the continuity through the limit switch if its closed you should read resistance if it's open the meter will read OL.
Posted on Jan 16, 2011
SOURCE: i need a list of
LED Flash list should be located on the inside of the unit's electrical panel by the wiring schematic, and by counting the flashes in between the longer pauses should give you the diagnostic code. A continuous steady flash can also mean normal operation, and something else on the inside could be holding you out like a float switch tripped (located on emergency pan underneath Air Handler Unit If Applicable) etc.
Posted on Jul 05, 2011
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
Gas furnace wont light
if pilot light is on, probably should be a knobs with settings for PL only, on, or off.
Nov 09, 2013 | Heating & Cooling
We have Lennox Elite Series furnace and central air. Blower would come on but air cond. did not. He replaced circuit board ECG1, I believe. I don't think he was sure if that would repair problem. Our...
Look at the inside of the cover on the furnace and it will tell you what's the code mean.
I think because was calling for Ac that's why you are having that blinking red light.
Turn furnace off on switch and turn it back on and that should clear error code .
To check your air conditioning unit that's the unit that's outside .
Check to see if contactor is pulled in .if it is and nothing is running then check the capicator. The capicator is the oval metal thing that's tuck next to the capicator with 3 wires attached to it .
If it bulky then it's bad .
That is the most common issue with these unit.
Jun 01, 2017 | Heating & Cooling
Red ring of death xbox 360 elite
Hi. Red Ring of death is a sign of hardware failure. It occurs, when GPU (graphics processing unit) becomes loose. GPU is fitted on motherboard, when ever mother board heats up GPU become loose and green light turn into 3 flashing red light. The vibration of system usually loose the soldering of the GPU this will freeze up your xbox 360. Here's a link on how to fix this issue. Please click here.
Sep 14, 2010 | Microsoft Xbox 360 Console
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Just installed a goodman furnance and a/c, there is a blinking light on furance control panel, and the furance motor runs constantly even with the theromostat wire disconnected. thanks for any help
the thermostat wire that you connected to the circuit board is only too long and touching anouther terminal or the insulation on the green wire is bad or last but hardly ever, the fan circuit board is stuck ,which the factory test the systems before shipping out, so the problem is HUMAN ERROR on your part.Thanks, from koolbreezes!
Jun 30, 2008 | Heating & Cooling
Heating & Cooling Logo
388 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
