Question about YouTube Videos
Pcv valve for a 2003 subaru legacy 2.0 location
3 Suggested Answers
  • 187 Answers
SOURCE: where is the pcv valve located on a 2004 corvette ls1
PCV valves go into the the engine crankcase.It might look different depending on the engine.
Posted on Nov 14, 2009
mcdevito75
  • 1970 Answers
SOURCE: i need the location of
mcdevito75 here, I did a FAST online search and your caddy may not have a PCV valve, most were replaced with a simple orifice in the cam cover. If you can, double check with most local Auto Parts Stores, most have a manual with picture and Local of the PCV valve or orifice. Or, check with any Caddy dealer. Hope I've helped out..
Posted on Oct 11, 2010
Pcv valve location
Look on the top of the valve covers.
May 09, 2013 | MagnaFlow 2003 Subaru Outback - 2.5L...
Replace coil pack on subaru legacy
Here's a link on how to replace your coil pack.
Mar 15, 2013 | 1996 Subaru Legacy
Subaru legacy b4 fuel gauge read empty when full?gauges jump about too
You have a fuel level sending unit that is not working properly. It is located inside the fuel tank.
Also, when you ask for help with your vehicle it would be very helpful if you could mention WHICH "Legacy" we are talking about. It seems that Subaru got "stuck" on the Legacy name - there are actally 9 choices for "Legacy" just for your model year. (see list below) There are also 2 different engines available for that year a 2.2L and a 2.5L.
1999 Subaru Legacy
Oct 10, 2011 | 1999 Subaru Legacy
2002 Legacy 2.5 Oil smell at idel?
that means you have an oil leak, the bad news is that the subaru is known for leaking head gaskets,it may be valve cover gaskets as well, you will have to jack up the car and take a look heres a diagram to help you locate the head gasket and valve cover gasket.there a gasket on each side of the engine.hope this helps.e277eb5.gif
Jan 30, 2010 | 2002 Subaru Legacy
Where is the ignition control module located on a 1990 Subaru legacy 2.2l
Center of firewall. It is a black plastic box with 2 screws or e the ignition module could be mounted below the steering column.
Jul 04, 2009 | Subaru Legacy Cars & Trucks
1991 subaru legacy
an engine needs fuel, air, and spark. it sounds like you have spark covered. try injector cleaner. if one brand doesn't work try another. at different times i've had luck with techron, seafoam, and lucas, which are about as different as they can be. its also possible that the problem is the injector itself or the wiring, but try cleaning it first. If the air filter or throttle body are dirty, which is rather likely on a '91, change the air filter and use use carb cleaner or seafoam. Also clean/change the PCV valve and clean the idle air control valve.
Feb 21, 2009 | 1991 Subaru Legacy
Battery Size for 2003 Legacy
GO TO YOUR PARTS STORE THEIR WILL BE A BATTERY BOOK LOOK UP YOUR YEAR MAKE AND MODEL.AND YOU WILL FIND WHAT YOUR LOOKING FOR AND THIS IS A EASY REPAIR YOU CAN DO IT.
Jan 17, 2009 | 2003 Subaru Legacy
2005 Subaru Legacy: Where are the O2 sensors located (both)
the o2 sensors are locted in the exhaust system. upstream is before cat converter, downstream is after cat converter.
Nov 22, 2008 | 2005 Subaru Legacy
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
