Question about Whirlpool Duet GHW9150P Front Load Washer
F30 ERROR CODE
Washer won't complete cycle
  • 106mecm Feb 18, 2009
    Hi, repairman told me to unplug washer and then retry...it worked..simply shutting it off wasnt enough to reset it...try unplugging washer when error code appears
  • 9 Answers
Your dispenser motor arm is out of position. take the scews out of the back of the units top and remove top and you will see the dispenser arm out of position.
Posted on Jan 28, 2009
This was the correct solution. I took the top off and not knowing where the arm should be, I applied slight pressure to the arm a couple of time. It didn't seem to move but when I tried to run the washer again, it worked. Apparently the are was stuck. Is this supposed to be lubricated periodically? This is a fairly new machine so I guess if it is going to be tempramental like this I should take out one of those extended warranties.
Posted on Feb 18, 2009
3 Suggested Answers
duby1990
  • 370 Answers
SOURCE: F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Posted on Nov 19, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Showing F-30 error code
F30, indicate an electronic communication problem with the washer. Some Duet models are equipped with electronic displays that will read "F30" when this error occurs. Models without displays instead illuminate a given combination of LEDs to indicate an error. In the Duet Sport, for example, when the "Wash," "Rinse," "Spin" and "Cycle Complete" LEDs are are illuminated at the same time, an F30 error is present.
Other comments about this problem suggest "storing" detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
I suggest visit and check this link: Use and Care Guide
Hope helps.
May 16, 2011 | Whirlpool Washing Machines
My Kenmore 11047512600 front load washer has a F30 error. it start the cycle and the dispenser cycles / clicks several times and then flash F30. I have already replaced the CCU module with no results.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Oct 24, 2010 | Kenmore Washing Machines
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus 110.47512600 Error Code F30 = Dispenser System Error. Have reset CCU multiple times. When cycle starts, dispenser motor runs for 3 minutes (~11 revolutions) then stops with F30 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2009 | Kenmore HE2 Plus Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal De
