Question about Vilano Fixed Gear Bike Fixie Single Speed Road Bike
Need to repair inner tube on vilano single speed bike
How do I change the inner tube on my rear tire
This is no easy task!
You will need to remove the rear wheel to access the wheel, tire, and inner tube
Unless you have a single speed rear axle, you will be needing to disconnect the multi-speed gearing, which you may not really enjoy.
God bless your efforts.
Apr 19, 2016 | Schwinn 24in Riverside Girls Cruiser Bike...
I need a step by step on how to put together my bicycle
This website will probably help
http://www.instructables.com/id/How-to-Build-Up-a-Bike/
Mar 19, 2015 | Vilano Performance 700C-21 Speed Shimano...
Inner tube size for a transeo gt 2.0 medium size bike
unfortunately you have to buy a new tube...The size you need is embossed on the sidewall of the tire.
Jul 10, 2013 | Cycling
Tyres keep going flat repaired many times replaced inner tubes still got problem
I'd check the inside the rims, there must be something rubbing against the tube. There is a product bike shops sell that is basically a solid foam inner tube. Check out your local bike shop.
Dec 09, 2010 | Quinny Baby Gear
How can I fix a bugaboo rear wheel
Need to know what's wrong with the wheel? If it needs a new inner tube it's a 12.5 x 175-2.25 your local bike shop can get you one. This inner tube many strollers examples are the Quinny Buzz 3 and 4 (rear), Quinny Speedi SX (rear), Quinny Freestyle, Maxi Cosi Mura 3 and 4 (rear), Bugaboo, Phil and Teds E-type, X-Adventure, Joolz Bloom, Joolz ZZZ One, Joolz Day, Teutonia, Easywalker, Cossatto Mobi (rear), Baby Jogger City Classic Single (front and rear) and Double (rear) and many more.
Nov 26, 2010 | Bugaboo Frog Stroller
Flat rear tire
A bike shop may be able to help you. Maybe you could just repair the tube with a tube repair kit, available anywhere bicycle accessories are sold.
May 04, 2010 | Schwinn 12" Roadster Tricycle
Inner tube front wheel quinny speedi
just go into any bicycle shop... i just got mine repaired today :-)
all bike shops have tubes the right size, they are pretty standard, failing that.. ebay have them . hope this helps.
Apr 30, 2009 | Baby Gear
Inner tube
Try a bike store. This is a standard sized inner tube for kids' bikes (12"). I got mine at our local bike store for a lot less than Bugaboo charges.
Apr 28, 2008 | Bugaboo Frog - Aubergine Stroller
Vilano Fixed Gear Bike Fixie Single Speed Road Bike Logo
23 people viewed this question
Top Vilano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Vilano Cycling Expert? Answer questions, earn points and help others
