Question about Dremel 3000-1/24 Variable-Speed Tool Kit 3000-1/24
Stuck on high speed
No longer have varible speed. only on/ off with highest speed the on setting
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
My fan is stuck on high
Boot into the BIOS (press F2) and look for a "Thermal Setting".
Make sure it's not set to the highest setting. You can adjust it to your preference and make sure to save before you exit.
Apr 11, 2014 | Dell Dimension 8250 PC Desktop
A/c switch not working only on highest setting
Neither probably.
There should be a high speed relay that powers the blower on high only.
Jul 27, 2012 | 1996 Dodge Ram 1500 Club Cab
The air conditioner isnt blowing hard
Do the blower speed settings still work, just weaker? Or is it just one low speed all the time? If you can still change the speeds then it's a weak blower motor. If its just one low speed all the time, (same speed for high and low blower speed settings) then you need a blower motor resistor.
May 03, 2011 | 1997 Ford Contour
I was wondering if there are different fan speeds for my tempstar joist hung furnace and where do i find these
Generally ther are at least three speeds and the wiring should be on the motor if they are varible speed. There should be a wiring diagram on a small plate or sticker on the side of the motor.Hope this helps you. Thanks
Dec 27, 2010 | Heating & Cooling
Ceiling fan stuck on high
I found out that the capacitor and switch is shortened. I un-shortened, and it got to low, mediium, and off.
Apr 27, 2010 | Hampton Bay 24750 Huntington III Ceiling...
2001 Ranger XLT heat and air conditioning only work on high speed
there is a flapor motor that is controled by vacume, check for leaks in the vacume lines on the engine.
Sep 30, 2009 | 2000 Ford Ranger SuperCab
Fan switch only works on the two highest settings
the various speeds are controlled through resisters (spring-like in apperance) one of different value for each speed, none for highest speed as the power gets to the blower uninpeeded . the resistor pack should be located on the center of the firewall, held by 2 screws. thats under the hood. where the engine bay ends....
Jul 22, 2009 | 2003 Buick Century
Dremel 3000-1/24 Variable-Speed Tool Kit 3000-1/24 Logo
46 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
