Question about Quasar SP-3232 32" TV
Direct tv manual for programing the remote to a tv
Need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Oct 24, 2009 | Philips Televison & Video
RCA DIRECT TV UNIVERSAL REMOTE CODE FOR SONY TV
If you have the RCR450 remote, the manual is here =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Sony TV are 1002, 1218 listed in the back of the manual.
Nov 08, 2008 | RCA RCR450 Remote Control
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
I want to program my remote control to work with my direct t.v.
Look in the user manual for your remote.
You should find a table with brands and types of devices.
Your direct tv should be listed as such.
There will be a number code for the direct tv that you will need to program the remote with.
The manual should also tell you what buttons to press in order to program.
Otherwise, have only the direct tv receiver ON.
point your remote at it and press the tv button and then the power button on the remote and hold it down while pressing the cursor up and down buttons. (not channel up and down. The up and down are the ones to select other things on the remote with.
When you have the right code the tv will shut off.
After it has shut off stop pushing buttons and then press the power button on the remote.
Your direct tv should now be programmed to turn on and off with the remote.
Note: be sure when you turn various devices on or off, have it selected for that devices you are trying to turn on or off.
Apr 30, 2008 | Televison & Video
Cant program directtv remote to sony tv
I'm not sure of your model number but those remotes use the NEC codes and the variants on the NEC codes. If that code set is not the databse, you may have to "learn" it on your particular remote.
Good luck
Mar 20, 2008 | ViewSonic N3251w 32 in. LCD HDTV
How do i program my remote
I went to the Comcast website and there they have directions to program their remote. The only problem is there are several remotes listed and it is difficult to pick out the one you have so it is a bit of trail and error until you find the right directions.
Feb 07, 2008 | RCA D770 Remote Control
Remote
I think the Direct TV remote has a scan feature where it'll go through all the TV codes 1 at a time. Then if you see the TV go off, you stop the scan cycle and store it. Read the manual on how to do that. If it never turns off, then it's not compatible.
Geno
Jan 24, 2008 | Televison & Video
Cannot program Direct TV to Sylvania 32"LCD TV LC320SS8
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
here are the code for your tv: Sylvania 10054, 10030, 10171
Dec 01, 2007 | One For All URC-3021 Remote Control
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
Oct 18, 2007 | Vivitek V37835 46 in. LCD Television
Ilo TV, universal remote
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Mar 16, 2007 | iLO 2600 Television
Televison & Video Logo
16 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
