CANON PC735 COPIER, PAPER JAM LIGHT KEEPS COMING ON BUT THERE ISNT ANY PAPER OR ANYTHING BLOCKING THE MACHINE, TRIED RESETTING IT NOTHING WORKS PLEASE HELP. IDENTICAL PRBLEM....
  • 86 Answers
I believe it to be a mechanical malfunction.
but you might want to check the user manual for troubleshooting before sending to repair.
here is a link to download the user manual:
http://www.devicemanuals.com/guidedownload/Canon-Personal-Copier-PC735-User-Guide--TkRBNU9Uaz.html
Posted on Jan 27, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Kindly check the wiring of paper jam sensor. It could be faulty and needs a replacement
    President:
  • 2,110 Answers
Check rear door for paper fragments check paper jam sensors ussally one front middle and rear make sure they arn't stuck, model make?
How do you clean sensor on canon pc735
Find the sensor and make sure no paper particles are blocking it.
Oct 18, 2016 | Canon 730i Laser Printer
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
Canon PIXMA MP2the paper jamming light is staying on. there is no
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 26, 2010 | Office Equipment & Supplies
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
May 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
For the problem with the personal copier pc735 paper jam, I had the same problem. I was told the problem might be fixed by downloading the drivers and reload them. The PC735 I have does not have drivers nor a scan. My problem was a spring fell off on the idler gear and had to be reattached. I then cleaned the interior and this fixed the copier. You might look to see if a spring came loose on the back side of the bottom frame. I'm no machanic so I had a canon rep fix it for me. This fixed my problem. No more paper jam light.
Bob At DottyW4658@aol.com
Jul 16, 2008 | Office Equipment & Supplies
122 people viewed this question
jasbo
jasbo
