Question about Kenmore 67082 Electric Dryer
Oasis dryer 67086
I have only had the set since may and it did not come with a manual What is a PF error on the dryer?
  • 5,911 Answers
PF is a power failure fault. This indicates that a power failure occurred while the dryer was running. You can press START to continue the cycle or PAUSE/CANCEL to clear. Have you had any storms lately, or power outages? If you haven't, and this continues to be a problem, you may have your receptacle checked to ensure that you have the proper voltage at the outlet (roughly 220-240 VAC). If you notice the plug or receptacle as burned you may have a loose wire causing the problem. The wires at the terminal block of the dryer should also be checked to make they are tightened properly. Unplug the dryer before attempting. I hope this helps you.
Posted on Jul 21, 2007
SOURCE:
I have Kenmore elite oasis electric dryer when you push start button it goes to pf code ive tryed holding down start button & it just flashes & is back to pf code how do I reset it ?
try unplugging it from power or tripping the circuit breaker(which might be easier). then re energize it and see if it resets. good luck.
Jul 29, 2016 | Kenmore Dryers
Maytag dryer has PF error code, but when use a extension cord it works fine?
Must be something wrong with the cord itself PF means power failure:
Codes and manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Maytag Neptune MDG9700A Gas Dryer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Mi secadora electrica oasis kenmore elite aparece un codigo PF que significa eso como puedo resolverlo
PF means power Failure unplug hold the cancel button for 3-5 seconds if the pf doesnt disappear then unplug the unit for 7 minutes this will make the control reset on the board if the pf still doesnt fade then you would have a control issue and most likely have to replace the control or call a technician if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Feb 26, 2011 | Kenmore Elite Oasis 6809 Electric Dryer
PF code but I have power at the outlet.
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Dec 18, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
If no-go.. the timer is failed due to a power spike and must be replaced.
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore 67082 Electric Dryer Logo
115 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
