Question about EliteGroup PM800M2 Motherboard
No usb or lan connection working
None of my usb ports on the back of my computer work. as well my connection for my lan to modem does not work.i have installed a usb expansion card and it works fine
FACKYOURMOM
Posted on Jan 27, 2009
Hi, the ethernet port located in the back of my computer appears to be faulty. I am unable to connect to a modem/router successfully due to this problem, also my USB ports don't appear to be working. Can...
If your lan card is faukty then you have to replace the LAN card. But as regards the USB ports not functioning the best thing to do is to install the usb drivers for your PC. When you install the USB port drivers for the PC the PC will be able to accept plug and play USB internet modems.
The drivers for your usb port can be located when you go to device manager select USB ports and it will take you to the drivers for the ports.
Hope this solution has been helpful?
Dec 30, 2010 | Computers & Internet
I have connected my DI-104 Router to my Motorola Surfboard modem and have two LAN cables to two other computers. However, neither computers recognize the connection. I have my main computer connected via...
Turn the router off.
Use an Ethernet cable to connect one computer to one of the 4 'LAN' ports on the computer.
Turn the router on.
Click Start
Click Run
Type CMD
Press ENTER
Enter IPCONFIG /RENEW
Press ENTER
Look for lines of output like:
IP Address. . . . . . . . . . . . : 192.168.40.150
Default Gateway . . . . . . . . . : 192.168.40.1
Open Internet Explorer.
Enter: http://192.168.40.1 (if that's the IP-address on your computer for the 'Default Gateway').
You should see a D-LINK "login" web-page.
Try an ID of 'admin' and a 'blank" password.
Once logged-in, you can check the router-settings, and then "configure" it.
Jul 17, 2010 | D-Link Express EtherNetwork DI-604 Router
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
My usb ports on the back of my motherboard dont work
Check that the USB and LAN functions are enabled in the board's BIOS setting. If everything is set properly and they still don't work, you could have a bad motherboard. Check into the warranty if the board is new enough, or just use expansion cards to replace the lost functions.
Jan 27, 2009 | EliteGroup PM800M2 Motherboard
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Ethernet cable port does not worked only the usb port worked
Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
EliteGroup PM800M2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
