Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
Smeg dishwasher problem
The cycle starts but it gets to the main wash and no water is going through the machine but i can hear water going out the waiste pipe so the dishwasher isnt getting any water inside to wash any thing. the 2 lights on left come on after a while too . any one know what i need to prepare look for tomorow when i start to repare ect ???
  • 1 more comment
  • jez stanley Jul 20, 2007
    hi.
    when you say ''Be aware you should disconnect the power cable from the machine before doing it !!!!! ''
    do you mean disconct the power/plug ??
  • jez stanley Jul 21, 2007
    sort of got the dishwasher goig better , well atleast its going through more of the program before stopping.
    now the error lighs 2 and 4 ( 1 being from left 4 being far right )cannt find the fault in the manuel..
    whats that mean ??
    how do you know what no. the error codes are too as ??
  • jez stanley Jul 22, 2007
    might have got last post wrong, i think i needed to say its lights 1 and 3 showing and not 2 and 4..
    can you help??
    New Friend:
Detergent not dissolving in machine when in use
Posted on Sep 08, 2013
  • 641 Answers
Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
Posted on Jul 20, 2007
Dishwasher cavitates. I have a Smeg DI612CA9
Does the drain hose loop up to the top of the unit before going to the sink drain? If it goes down first it may be siphoning or draining by gravity.
Aug 08, 2013 | Smeg Dishwashers
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
SMEG SA 425 x Dishwasher - washing spinners stopped!
Can you hear the wash pump operating during the cycle? Pump could be faulty or blocked, or the pcb could be at fault
Jan 06, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Smeg dishwasher
riff...not sure what the bits are...first, they may be food crumbs or the like. Dishwashers have macerators to grind up food particles but they have no really good way to get rid of them in the wash cycle. Scrape plates of any solids before loading them. If the material is shaped like water droplets, you may have hard water stains. Use Jet Dri or a cleaning product which claims to help and use the amount specified. Your water temp may be low...it should be 125F or better. If you can run the hot tap and put your hand under it...it isn't hot enough. You can also use the heated water setting to deal with this.
Dec 11, 2007 | Smeg DWI614 Built-in Dishwasher
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
559 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
