Question about Sony CDX-GT54UIW
Sony cdx-gt54uiw wont change stations
Volume will go up and down, can not change cd tracks
rteemon
  • 578 Answers
SOURCE: I want to replace a Sony CDX-C5005 radio/cd with Sony CDX-M10.
you can try but the connection may be different
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: MY Sony CDX-R3000 will only play CD's. It will not
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
Posted on Oct 08, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
SOURCE: How to change time on Sony cdx-gt430ip
how do i get the desplay to show so i can see what song is on and the volume
Posted on Mar 24, 2010
SOURCE: Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
i have the same problem, it was a factory fit and the garage checked it and all the connections were ok, it appears to be a fault with the receiver.the radio is just 3 years old.
Posted on Mar 25, 2010
Sony CDX-GT54UIW
What is the problem you faces with this set. Provide more details please. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Oct 09, 2016 | Sony Car Audio & Video
Guys, I have a CDX GT610, the issue is that is
hi marco, the problem seems with the switches on the face. make sure that ALL switches have a "click" sound when pressed down. if not then that switch needs to be replaced. faulty switches can cause the face functions to work erratically. to try another route use your unit with the wireless remote control to check if all functions work well. cheers.
Sep 06, 2013 | Sony CDX-GT610Ui CD Player
Sony cdx-gt610ui buttons won't work
Guys,
I have a CDX GT610, the issue is that is not possible to change stations, even if I try with the push buttons to record the stations, it remains on the same station (number 3 in my case), besides the volume gets high if I want increase the volume, any suggestion about it??? please let me know
Best Regards,
Marco Hernandez
Feb 26, 2013 | Sony CDX-M630 CD Player
I have a sony mp3 xplod car radio, buttons wont work on it to operate probaly, any suggentions as to what is wrong?
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Dec 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
My sony cdx s1000, the source button does not work,therefore i cannot get the radio to tune into any stations.the cd player works but the various buttons have no effect on volume,skip tracks,shuffle etc.
you may have a bad switch. if you can you can use a multimeter to check the resistance of the switches. anything less than a few megaohms, denotes a bad switch usually.
Nov 12, 2010 | Sony CDX-S1000 CD Player
How do you change the time on a sony cdx-gt510 stereo
Push & hold down the volume knob until "clock adj" appears on the face (a couple of seconds). Then turn the volume knob, left or right, to adjust the time up or down
Nov 28, 2009 | Sony CDX-GT510 CD Player
Can you change the radio stations without the remote?
Yes. This is a link to Sony for your CDX-CA900X operating instructions. Look on pages 13 & 14 for changing radio station w/o remote.
http://www.docs.sony.com/release/CDXCA900X.pdf
Nov 27, 2009 | Sony CDX-CA900X CD Player
Ineed help with my sony cdx-c7000x it will not change channels on
Try cleaning the contacts on the panel and socket
Mark
Nov 17, 2008 | Sony CDX-C7000X CD Player
SETTING THE CLOCK IN THE CDX-F7700
press the display button until the time appears on the display (instead of the radio station or cd track). once on the time press and hold the display button and the time should flash. use the sel (aka select) button to jump from hours to minutes.
Oct 16, 2007 | Sony CDX-F7700 CD Player
Sony CDX-GT54UIW Logo
55 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
