Question about JVC LT-32D210 32 in. LCD TV/DVD Combo
Tv won't come on
Does not respond to remote or manual on/off button.
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Jun 01, 2012 | Samsung Televison & Video
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
Toshiba 32a14 does not respond to remote control
Hello
There is a infrared light sensor inside the TV which detects the infrared rays emitted from the remote control, when we press each button on the remote control. If this sensor has got damaged, the set won't respond to any remote control handset. The sensor can be located just behind the infrared sensor window at the front panel of the TV. To access it, you have to open the TV. It is a three terminal component, will be soldered diretily to front panel circuit board, of with the main baord itslef. Will look somewhat brownish black in colour. There are so many types can be seen . Just look what type if fitted with your TV.
2_4_2012_6_58_45_am.jpg2_4_2012_6_59_07_am.jpg2_4_2012_6_59_34_am.jpgSee some models infrared sensors. Check out which type your TV has.2_4_2012_7_00_45_am.jpg
Feb 04, 2012 | RCA Televison & Video
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at thomas.faust@dishnetwork.com. Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
JVC LT-32D210 32 in. LCD TV/DVD Combo Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
