Question about Electronics - Others
Failing to format
When i insent the flash, it says format then when i try to format, it says cant format
    Problem Solver:
  • 5 Answers
Maybe try some 3rd party software? partition wizard is a nice tool that can help manage your disks and hard drives.
Posted on Jan 22, 2013
WANT to format my write protected pen drive ? please help!.
Use disk part in cmd but us the CLEAN command first and then create a new partition
Dec 06, 2015 | Electronics - Others
Iwisoft swf to video failed to open file please help
I doesn't use the tool, instead I'm using the Kvisoft swf to video converter. I've used it several times already and it works in Flash to video conversion.
Aug 11, 2012 | flash-swf-converter iWisoft Free Video...
Hello i have a problem with my Citizen Cyber Aqualand NX. He is flashing FILE. I have tried to do the garbage collection, but he said Fail. Also the Formatting of the Flash memory dos not work, and said...
I got last year same problem, easy to resolve :) I was doigng GC and i got my watch in failur exactly like yours. Solution? Buy 4 fresh, alkaline, good brand batteries. Put it in charger unit. Let the watch to charge for 12hours. After do garbage collection again or formatting if you cant do GC. If you got again fail, charge again it for 12 hours. I did it for 3 times and...the third days, I got "Done!" and solved :) It happens when battery is not full charged, so do GC just when is very charged. I love my Cyber, but sicne seems that GC collecting drink a lot of energy seems that low level battery doesnt let the inside flash memory to work well when try to format/GC datas.
Jun 01, 2011 | Citizen Promaster Cyber Aqualand Nx Dive...
I cant format my 2GB Kingston flash disk, when I plug it to the computer it is reading removable disk and when i try to format it it will start formating but failing to be formatted successfully.
that problem is usually caused by a failure of the hardware to properly recognize the USB drive, clean the contacts with WD-40 or with a contact cleaner. Try a different USB port.
Hope this helps
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I can't format my 4G flash drive! Keeps saying windows was unable to complete the format...!!
Hi
Please try the following
1) Put into another USB port and try
2) Try formatting in another PC
If the above 2 fail then unfortunatley the flash drive is 'broken' and will need to be replaced
If this has been useful please leave vote, feedback
Regards
Feb 10, 2010 | Electronics - Others
My flash cant format
the problem is from your memory IC inside the Flash thats why refuses to format due to cold solder or some pins need fresh solder. so many times i fixed these kind of problem not only Genx.
Jun 07, 2009 | Electronics - Others
Cannot format 400gb usb flash drive
I had the same problem.
Go to the Dos Prompt via run cmd
format d: or whatever your drive letter is.
This worked for me.
PS these flash drives are copies and are made in China. I just bought one for $7.50 Yes that is seven dollars and 50 cents.
Apr 21, 2009 | Electronics - Others
I cant format my transcend 2 gb pen drive it says write protected
do you see any switches on the side of it ? if so move it to the other position and try again.
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Problem with nokia 6600 startup
I the 3button format failed, the only solution left is to format/SW flashing through a flasher.
Apr 02, 2008 | Nokia 6600
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
