It starts then sounds as if it's draining then stops beeps and flashes .50 we have cleaned all filters that we knoow off!
It is possible that the
machine does not start off the cycle because there are errors or feedback from
the inputs. For the program to start up the main program controller must
initiate the INLET/PUMP MOTOR/DRAIN to work
when it is commanded .If this does not happen then the voltage at these
points must be checked or the fault
relates to no voltage/drive from the controller. This means the controller is a
suspect. Check how
to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If the
water flows then the flow should be good, if not the inlet valve is bad or there
is dirt in the filter. Also check the flow at the inlet of the water line. What
is most important for the motor to start functioning is that the door switch
must be ON when the door is shut or this will be an error for starting the
motor. The water pressure must be good and the spraying must be seen to be
good. If there is low pumping or pressure then the spray arms will not turn
around to inject with pressure. If so
the pump must be checked for clogging. To replace
check this link: Finally
after the wash the drain valve will be activated, the water is allowed to come
in to rinse and then finally the drain valve/pump activated so as to drain off
all the water. Make sure
that a fault in any of the cycle will relate to the specified action, so check
the command from the program module and then the executing device be it the
valve or motor or pump. Please check the link below:
