Question about HP Photosmart 3310 Printer
HP PHOTOSMART 3310
I HAVE A 3310 WHICH IS A GOOD PRINTER FOR ME. HOWEVER THE 2 HINGES THAT HOLD ON LID OF THE PRINTER IS BROKEN MAKING IT HARD TO REPLACE CARTRIDGES BUT NOT IMPOSSIBLE. ARE THESE PARTS AVAILABLE FROM SOMEONE ON-LINE AND IF SO WHO. MY SEARCHES TURN UP NOTHING.
THANK YOU
    Scholar:
  • 87 Answers
We have parts machines..
Inkworks
866-381-0541
Posted on Feb 10, 2009
I changed a printer cartridge and the lid is stuck open. HP 3310 Photosmart. I did reseat the cartridge I changed to no avail. I am most curious how this can be fixed without forcing the lid down. Thank...
hello, well, you can take off the right cover, with printer unplugged, and disconnect cables that connect to the scanner top cover area. the hinges have press lock that will require you to press up, and slide towards the front and lifting up at same time. the scanner will come off, using #10 torq bit, take hinges out of machine, if you some white grease or light weight lithium oil, use it in and around the actual hinge area, basicly what your working against is plastic on plastic, with a powerful spring, so do this carefully and try not to pinch your fingers, it hurts alot. try slowly to open and close hinge slowly, if it does not move freely, don't force or it will break, that spring used is under alot of pressure, so do it slowly, lube and try to move, lube and try to move. when it works smoothly put back together
Oct 12, 2010 | HP Photosmart 3310 Printer
The door hinges on my 3210 have broken. can i get replacement hinges
hinges seprately cannot be replaced . for support needs you can call hp tech support team 1800-474-6836 ask for printers and ask for the same. if its under factory warranty the entire printer can be replaced//
May 07, 2010 | HP Photosmart 3210 Printer
The plastic hinges on my 3210 that hold the top on
Is it just stuck? Because if it is just use WD40 on the hinges. If it's broken, then sorry. Can't help you.
Jan 18, 2010 | HP Photosmart 3210 Printer
Printer lid wont shut
Make sure you have successfully seated the cartridges you replaced. They may be preventing the lid from closing.
Dec 19, 2009 | HP Photosmart 3310 Printer
I cant close the lid of my
Same thing happened to my printer last night (never happened before) and I too am looking for some release latch....so frustrating and I don't want to force it closed...
Nov 10, 2009 | HP Photosmart 3310 Printer
The lid to my hp 3310 is stuck open.
Check back by the hinges there should be a catch that locks the lid up just release the catch. If yours does not have this check to make sure you don't have to lift up again to release the lid. These are the only problems with that type of printer that I've seen, I hope this helps if not let me know and I'll do some research and try to find an answer for you. Good luck.
Sep 25, 2009 | HP Photosmart 3310 Printer
Carriage Belt is worn and slipping 3310 HP. Where do I purchase?
The 3310 parts are not distributed anymore.
This is one of biggest sellers, and does not have any part listed for 3310:HP Photosmart Printer Parts.
The only option is grabbing spares from Ebay, like this one below:
eBay.com.sg: HP Photosmart Printer 3310 REPAIR PARTS
Mar 01, 2009 | HP Photosmart 3310 Printer
HP 3310 Photosmart AIO
Try this bellow link if it is of any help for you:
http://partsurfer.hp.com/cgi-bin/spi/main
Good Luck
Aug 19, 2008 | HP Photosmart 3310 Printer
Unable to close Lid
Sounds like the hing on back is broken. Look on the back of the cover, there will be 2 hinges holding the scanner on. Probably a piece of plactic broke and is hanging up one of the hinges.
Possibly a small spring.
Feb 28, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
278 people viewed this question
Ben Johnson
