Question about Behringer FCB1010 MIDI Foot Controller with Two EXpression Pedals
Fcb1010 from 220 to 110v
220v to 110v
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
hi,
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
Can this unit be easily converted from 110V to 220V for use in Europe?
im pretty sure they sell a converter kit for pretty much anything, so i wouldnt see why not
May 16, 2011 | Peavey XR 8600D Class D Powered Mixer
It wos plukt into 220v and dos not turn on
you might have a problem with the power source inside the keyboard
Feb 14, 2011 | Yamaha Portable Keyboard with 61...
The unit input voltage is 110 volt and was plugged into 220v outlet. . the input winding is now busted. . i was hoping to know the secondary voltage of the transformer. . i was planning to replace the...
The winding is center tapped. It generates +/-24.5 volts DC. Based on it being a capacitor input filter, we need a peak voltage about 1 volt higher to account for the droop of the capacitor and the .7 volt drop of one silicon diode...
Since we need 25.5 volts peak then we need that divided by 1.414 RMS out of ONE side of the center=tapped secondary... So our secondary voltage is 18 volts either side of center.
You will need a 36 volt center-tapped secondary. Here is one that would work:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=162J36-ND
This has two 18 volt windings that you would connect in series and a dual primary you can set for either 120 or 240 input. About $19 US.
Dec 29, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
110v is pluged to 220v. What part of the organ damage?
This totally depends on what organ you have.
Many would blow the input fuse. Some organs have a wide range power supply that would use either 110 or 220.
What model is it?
Apr 15, 2010 | Yamaha Music
Europowre pmp 3000 a120v or 220v?
There is a jumper (JP1 or J1). If you cut that jumper, the mixer will operate for 220V. This power supply is the same with the ones used in desktop computers. I did that to my mixer bought from US made for 110v. I replaced that jumper with a switch (from a desktop power supply), I made a whole and I fixed the switch on the pack panel of the mixer. So now, I can switch it manually for 110v or 220v. It's working perfectly. I tested it for long time and no problems. Good luck.
PS. I called the Behringer technical support in the US and they weren't able to teach me that. So I figured it out myself after a big research. See the pictures about my project. :)
Feb 05, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Line 6 Spyder 112 got plugged into 220v now just smokes.
The power supply is bad. The transformer more than likely survived however some fuses and possibly filter caps could have been blown. Also some of the regulatory circuitry for switching or digital lines could have been damaged. This being said you should be able to get the amp working again without any problems.
Jan 09, 2010 | Music
Behringer FCB1010 MIDI Foot Controller with Two EXpression Pedals Logo
74 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
