Question about Acer Aspire™ T180 PC Desktop
ACER T180 Computer locked up while online. Control, alt, del wouldn't work. Turned computer off and rebooted. Went to the Safe Mode etc. screen. Chose the start windows normally option. I get the Microsoft word with the flashing green underneath it, but then the screen just goes black with the cursor showing on it. Have re-booted several times and the same thing happens each time.
Had to reload some drivers in the safe mode option and this solved the problems.
Posted on Jan 28, 2009
Updated antivirus an it said to reboot an i did an now its a white screen nothing will load
It probably crashed explorer. If you hit ctrl+alt+del and choose run task -> explorer.exe it should show up.
Mar 07, 2011 | Acer Aspire 5050-3242 Notebook
PC locked up.
reboot in to safe mode (follow these steps)
1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start "windows with networking", and then press ENTER.
See if your DSL line works in that mode. If it does, then we simply need to clean up your windows startup applications.
Who is your DSL provider?
Jan 05, 2008 | Acer Aspire™ T180 PC Desktop
The Acer travelmate 240 boots up and after the Acer screen goes to the windows didnot close properly screen and then back to the Acer screen. How to boot it up ?
First try to start in safe mode:
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Apr 03, 2010 | Acer TravelMate 240 Notebook
Error message ntdlr is missing running XP service pack 2
do a system restore from the system repair when you first start it up it should tell you what key to press once you get into system repair you can use system restore to fix the problem or either go to safe mode and do it from there then it will fix your problem
Aug 02, 2009 | Acer Aspire One AOA110-1588 Notebook
My acer laptop get stuck after booting, no response from keyboard, power button and turning off i need to take the battery out. any help? Thanks
hi,
Try to reboot the computer then press F8 while going to boot on windows logo then choose the safe mode. Check if you can go in safe mode, after that check the CMOS setup of the computer by pressing del or F1 on the key board, I sure that the is something wrong on the operating system of your computer.
Jun 27, 2009 | Acer Aspire™ T180 PC Desktop
How to start in safe mode
Windows XP and Vista
Using the F8 Method:
  1. Restart your computer.
  2. When the machine first starts again it will generally list some equipment that is installed in your machine, amount of memory, hard drives installed etc. At this point you should gently tap the F8 key repeatedly until you are presented with a Advanced Options menu.
  3. Select the option for Safe Mode using the arrow keys.
  4. Then press enter on your keyboard to boot into Safe Mode.
  5. Do whatever tasks you require and when you are done reboot to boot back into normal mode.
May 30, 2009 | Acer Aspire™ T180 PC Desktop
My computer wont work
There are many possible causes for this kind of problem. With Safe Mode not booting, though, the possible fixes become few. Your best bet is to put your Windows CD/DVD in the drive and reboot the system by turning it off and back on or hitting the reset button - hitting enter or CTL-ALT-DEL won't give you the kind of reboot you need.
As the system is rebooting, keep watch on the screen near the bottom - you *may* need to hit a key to get the computer to boot from the CD/DVD. Once it's started to boot from the CD/DVD, follow the prompts to re-install Windows.
If you get an option to format the drive, don't do it! Just choose to keep the file system unchanged.
Good Luck!
Apr 17, 2009 | Acer Aspire™ T180 PC Desktop
Monitor went black after changing resolution
Reboot you computer and spam F8 until you get the option to boot in safe mode then choose VGA safe mode or safe mode with network is fine also and change the resolution back
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Oxc0000098 error
hi friend,
That problems cure only one way. i.e., change and reboot the OS. All error are deleted.......
Jul 09, 2008 | Acer Aspire™ T180 PC Desktop
Acer laptop ....lost power when going online....when i plugged it in and rebooted it goes to black screen and ask me to either repair or start windows normally...i tryed both but it still goes back to the...
try to go to safe mode first, after that, shut it down and reboot to normal mode, usually it will work.
If it don't work, go to safe mode and move your files/data to d partition and after that reload using alt+F10
Feb 25, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire™ T180 PC Desktop Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
