Can't play my ps3 on symphonic wf2703 tv
I have hooked up my PS3 to my television and i have flipped through all the channels to see if my ps3 would work on any of them. I have also switched it onto game mode and it still does not work. I have tried to make sure all of the channels are added as well so when I went through all the channels. I have a remote that does not work, but after examining it, it seams to do everything that the buttons on the t.v. do. most of my channels are all black, white, and frizzy, which I assumed it should be that way due to the fact that I do not have my t.v. hooked up to any sort of channels. I have not used this television in about a year as well, but it did work back then. I see images on a couple of my channels, but not on any others. I'm not certain how these old televisions are. I have my ps3 hooked up like I did on my slightly newer t.v. that I left at home. I have read that I may need a video converter for these older televisions, but I am uncertain if that is true since my brother played x-box 360 on it.
3 Suggested Answers
  • 11 Answers
SOURCE: No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Posted on Sep 13, 2008
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
I'm trying to play my Xbox on a Symphonic Tv model
push the av/tv button in the tv panel.
May 03, 2013 | Televison & Video
How do i input tv to video mode
press the tv/video button at the front panel.
Oct 10, 2012 | Symphonic ST424FF TV
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
Green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
Jan 19, 2009 | Symphonic ST420FF 20" TV
PS3 to sony bravia
If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
Oct 26, 2008 | Philips 19PFL5622D/37 19 in. LCD...
My PS3 is not turning on right
Is your tv and HD or normal tv. did you ever connect it to an HD tv in the past? If so and you are trying to use a standard tv set, you need to hard reset the system. Call Sony Customer Support, they will walk you through the steps to reset the system. NOTE: every time that you hook the system up to a HD tv using the HDMI cables and then switch back to a standard tv, you will have to reset the system in the same way you did before.
Best Regards,
Aug 20, 2008 | Sony Playstation 3 (PS3) Console
Insignia LCD 26 inch
sum tvs cant take it this is a cheaper model try adjust bass and settinsg in the tv suround mode ect 3d mode adjust treble down
Dec 27, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
