Question about Sanyo CLT1554 15 in. EDTV-Ready LCD Television
I need a 2005 sanyo tv receiver power cord
It is a 12V 3.2A model CLT1554-02
SOURCE: Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Posted on Nov 03, 2008
  • 11 Answers
SOURCE: missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Posted on Jul 03, 2009
  • 1044 Answers
SOURCE: Which power cord for sanyo clt 2054 lcd 20" tv
Go to Sanyo web site and then click on support where in you can ask them to help you out or give you the contact number of your local service center o.You can contact the local dealer OR Go to this website and look for the power cords for you TV depending on the country as I do not know where you are residing http://www.powercord-manufacturers.com/kp-sanyo-vizon-clt2054-power-cords-10591.html
Posted on Apr 14, 2010
cschindle725
  • 67 Answers
SOURCE: I have misplaced the power supply cord for our
any place like frys or best buy
Posted on May 22, 2010
micromatikal
  • 2777 Answers
SOURCE: i need the power cord for my tv and it says power
I would start by calling Sanyo and have them confirm what type of power cord you need. Most likely they will give you a free replacement or sell you one at minimal cost.
Give them a call at 619-661-1134
Posted on Sep 10, 2010
I moved and lost the power cord to my sanyo flat screen tv model no. CLT1554. serial no. B5490687877576. I was wondering where i could get another one
Here is a link where you can purchase the cord from ebay.
http://cgi.ebay.com/12V-AC-Adapter-Power-Cord-Supply-Sanyo-CLT1554-LCD-/350425528490?pt=LH_DefaultDomain_0&hash=item5196fd38aa
If you want to research more for a cheaper price or different site, just simply search your model number and the product will come up.
Mar 06, 2011 | Sanyo Televison & Video
Hi, im teddy from kenya. Im an electronics technician working on tvs. I have sanyo lcd tv model: LCD-47XR1 which is switching on but the display is black. please assist. thanks in advance.so far i have...
hi.. hope this help...try to check the power inverter that supply the screen lighting's. it should have 12V output for 24" below or 24V for 25" LCD and above....pls. rate and vote..good day
Feb 15, 2011 | Sanyo Televison & Video
I need the power cord for my tv and it says power (dc in 12v)
Sep 10, 2010 | Sanyo Vizon LCD-15A2 Television
Missing power cord 12v
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
SANYO TV AVM278 do not start. when you push key "power", you hear more than one time"click"( the sound of the 12v dc relay), and then the screen flashes certain times.sometimes it begins to work after the...
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 24, 2009 | Sanyo DS25390 TV
Power Cord
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
POWER CORD IS NEEDED!
I have same model TV that I am looking to get rid of. Would you like to make an offer for it? I am located in chicago, il.
Apr 25, 2008 | Sanyo DS25390 TV
Sanyo CLT1554 15 in. EDTV-Ready LCD Television Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
