Question about Canon Cameras
Canon sd 1300 lens error
Lens error
  • Canon Master
  • 4,738 Answers
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Posted on Jan 23, 2013
camerawes
  • 36 Answers
SOURCE: Canon SD 850 says lens error,
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Posted on Jun 10, 2008
camerawes
  • 36 Answers
SOURCE: Canon power shot SD 750
The lens needs to be dissasembled and repaired or even replaced. A good camera repair tech can do this for around $100.
t00nz
  • 4738 Answers
SOURCE: Canon SD 870IS - lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 10, 2009
t00nz
  • 4738 Answers
SOURCE: Lens Error
Posted on Jul 04, 2009
  • 3 Answers
SOURCE: My canon powershot sd 1000's lens will not open.
press the button with your peenniiss
Posted on Oct 28, 2009
What do I do when lens would not open?
  • is your batteries fully charged?
  • if you are using old rechargeable batteries try replacing them
Aug 09, 2014 | Canon PowerShot SD-1300 IS 12.1 Megapixel,...
Canon power shot SD 1300 IS says" lens error" will shut down automatically
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 10, 2011 | Canon PowerShot A560 Digital Camera
I was taking photos when suddenly my Canon PowerShot SD 1300 IS IXUS 105 read "Lens error. Will shut down automatically. Restart camera." Then the screen went blank. The lens will not retract....
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 25, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My camera canon power shot sd 1300 is dont work it say error reset automaticalli
You could be having a power problem, or lens issue. The following blogs discuss things you can try to get the camera working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
If nothing helps, contact a local camera shop to get an estimate for repair, or contact Canon support:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Mar 01, 2011 | Cameras
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Jun 09, 2008 | Canon PowerShot SD850 IS Digital Camera
Lens error
Comment by Bucko214, posted on 20.1.08
Whem I turn on my camera I have a lens error msg and the camera shuts down. camera has been sent to Ricoh they say they cannot repair must replace insides at a cost of more the the camera no solution
Jan 08, 2008 | Casio Exilim EXZ75 Digital Camera
Cameras Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
