Question about The Times Max ER-1500 Electronic Time Recorder, Fully automatic, Up to 4 columns, Automatic positioning (ER150... (ER1500) UPS System
EE-04 erreor appears on my time recorder
How do I input a problem using log
What does it give you? What is this 10exp11?
If you want to enter 7.8X10^11 type it as 7.8[EE]11. [EE] is the key [Exp[, or [EE] or [x10X]. The EE is a short cut for *10 to a power. The 10 must not be appear in the expression entered.
Nov 20, 2013 | Sharp ELW535 Calculator
Hand wheel turns very hard and erreor message c4 appears on screen stops sewing for five seconds then resumes
it could be a computer is messed up or the mechanical part of the sewing machine, the machine needs to be serviced
Feb 25, 2012 | Singer 7258 Sewing Machine
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
E-EE
Let us know the exact problem. From when are you facing the problem.
Feb 23, 2011 | The Times Max ER-1500 Electronic Time...
Error code 04ee on Dish network 722 vip HDD,
Hello this is luke. I do not know of any 04 ee error code on dish network. The closest will be 004. Try to check if it is coming from the receiver or from the tv by unplugging the receiver from wall outlet while tv is on. If the code stays, then it is from the tv, if it goes away with the lights on receiver, it is from the receiver. Let me know.
Jan 23, 2011 | DISH Network ViP622 DVR DTV Receiver /...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Camera open to erreor. unexpected erreor
try to replace the main camera..or replace the camera module
Jun 08, 2010 | Nokia N72 Cellular Phone
I have a Toshiba d-r18dtkb dvd recorder. Am
This is a known fault,solely affects toshiba dvd recorders and they claim is to do with the time/date signal it is receiving at the moment.They hope to have a solution by the end of the week(probably because it will be 04/03/2010 by then!).Call the tech support and log your fault on 08448560730.
Mar 01, 2010 | Televison & Video
Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Jan 09, 2009 | Texas Instruments TI-30XA Calculator
Ntl codes
2F EE 05 09 A1 46 E7 BA (NEW)
FD 70 D1 CD CD EA 08 7F
NTL CODES 1ST JULY
Jun 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Computers & Internet Logo
21 people viewed this question
Top The Times Computers & Internet Experts
David Payne
David Payne
Are you a The Times Computer and Internet Expert? Answer questions, earn points and help others
